Tell your Wife to either move back into the house, or buy a tent.bump_drft wrote: Wed Jul 30, 2025 3:14 pm Cleaning the filters has been on my agenda but it's hot as heck outside and my wife occupies the garage.
2.0 8V bottom end rebuild (by idiots)
Re: 2.0 8V bottom end rebuild (by idiots)
Pull the knob straight off using flat pliers and a rag/bit of rubber, as a cushion. A good grip and quick tug is the best way.bump_drft wrote: Wed Jul 30, 2025 3:14 pm It definitely feels like the cable isn't actually connected as the rotary spins so loosely I didn't even know it was cable operated!
The knobs are held onto the D shaft with a small flat spring clip, which may be missing, or the knob shank be broken which is common, due to being acrylic.
If broken, cut a grove all the way round the circumference and stick it back together using a wire, or strong thread, as reinforcement.
eyesoreracing
Oh my god, that link was horrifying!Dieselman wrote: Wed Jul 30, 2025 7:02 am As your car has rotary heater controls the airflow direction is cable operated. Check the cable is actually connected, the outer sheath is clipped securely and the flaps inside the heater box can move freely.
The A/c issue is most likely the switch is sticky, a strip and clean may sort it.
If the flaps are jammed you have this joy to look forward to. See thread viewtopic.php?f=6&t=6292&hilit=heater+flaps
I've been driving the car daily for a couple of weeks and the A/C works well when vehicle speed is high, but is basically useless when speeds are low. Radiator fans are running when the A/C is on, but are not very strong. But just when I was about to start checking voltage at the fan relay a new problem occured. There was a sudden THUMP noise under the dash, and the vents immediately went from full cold to full hot! The blend door actuator broke or fell off.
We need to figure out how to get down to this blend door and see what happened, but if that means removing the whole dash I might just light a match and run!
Your timing is impeccable, it sounds like the blend flaps were stuck so not shutting off the warm air flow, until you left it on full cold while testing and the actuator broke. The cooling fans running slowly is correct for A/c operation.
It would be worth opening the actuator motor unit and ensuring it is synchronised. There are a pair of dots on two gears that must be aligned, otherwise the motor might be over-driving at one end of the rotation and not driving far enough at the other.
I currently am dealing with a blend door actuator failure as part of a heater control issue.
You need to access the blend flap and see if it is seized, if so it's heater box out time, if not you may be able to perform an in situ repair. Fortunately the blend flap actuator is accessible on a Lhd Xm, not easily so on a Rhd, so I have the dash skin and heating ducts out of the car.
My actuator has broken the splined drive and was stuck on hot, so after ensuring the internal flap is free to move, rather than strip the heater box and replace I have used a self tapping screw into the internal heater flap shaft, twisted lock wire and epoxy adhesive to create a new splined drive socket. You need to be careful as the actuator lever is also the bearing for the internal flap to rotate on.
eyesoreracing
Thanks for the pictures, its really helpful to know what I'm looking for. I assume this is on the left side of the heater box. Is that near the (LHD) gas pedal? I'll start digging around there, I guess.
You should be able to access this by removing the left hand central carpet section and the under-dash panel.
eyesoreracing
We fixed the A/C! (for now...)
I lost count of all the failure modes we found, so let's walk through them.
The temperature knob was not attached to anything.
Because this thingy fell off. No idea how to make it stay in place, so I attached it to the knob directly.
Of course, then you can't install the panel, since the mounting screws hide behind the knobs. So I drilled a hole.
One failure mode fixed...
eyesoreracing
The blend door actuator looked fine and moved fine. Sounded familiar when I slammed it to full hot...
The servo moved when the newly fixed temperature knob is turned. But it was out of position when I tried re-installing it with everything set to the full cold position. I forced it into position, skipping some teeth as I did so. Seems it was overactuating in the past (I heard strange noises from exacly this location) and perhaps stripped some gear teeth.
Now, when I turn the knob to full cold, I can hear it clicking, as it tries to go colder than possible. If I back off the knob just one click, it stops making noise.
This is the servo if you happen to know of any crossover applications we might be able to find in California.
That's two failure modes...
eyesoreracing
The vent position actuator wasn't working because the knob cracked and metal tab that rests against the flat on the actuator is missing.
Superglue, a spring clamp and a scrap of metal cut off another spring clamp fixed that issue.
That's failure mode #3
eyesoreracing
Fan speed knob had a similar failure, but the metal tab was still there. But this knob has to be installed with the repair clamp in place, so to let it fit through the front of the housing, I had to grind the tabs off the clamp.
That's failure mode #4
