Hello Chaps....new owner
Re: Hello Chaps....new owner
Dieselman wrote: Sat Aug 07, 2021 6:16 am
citroenxm wrote: Fri Aug 06, 2021 6:03 pm
Will.. Do bendix cars not have this green relay above. I need to look Into a miss behaving lamp on a bendix M reg S2 car
The relay is inside a black plastic module screwed onto the Abs valve block.
If the fault is intermittent its possible the relay is sticking, if permanent then it's likely so be cracked solder joints, or one leg broken off the diode.
There are a number of wires, but one of the connectors has the pins all linked together to handle the current.
If you don't have a replacement module, you will need to cut the unit open and glue it back together after repair.
If you do have a replacement unit, I would like the faulty one to repair.
Thanks will. I have about 5 or 6 bendix abs blocks..
I'll get lexia on and see what it reports back.
Stickfinger
Post by Stickfinger »
MoT re-booked for Wed 3pm....
I have started making it look better, well the roof anyway because I think it had been parked under a pine tree near a beach !...the paint was gritty to the touch so I gave it a good wash and worked it over with a clay-bar before a sealer & polish.
Stickfinger
I have a Wet boot..... so I went looking for the reason.....As directed by Rob Draper I "may" have found it.
Ripped seal, badly applied silicon, top nut missing......I re-foamed it, cleaned it.....thicker foam used so the tail lights are on tighter now.
The missing upper nut would almost certainly allow water in.
Stickfinger
.....the MAD thing about that is they had fixed the "pulled" screw then did not use it :)
Post by White Exec »
Perhaps just careless with their nuts...
Stickfinger
BOOM!
Now the fun begins...
Great news, our A.
DownUnderXM
Orga / RP numbers: RP 8603
Post by DownUnderXM »
Congratulations - you are an inspiration!
Nice clean sheet, too...as expected.
So..do you like driving the Xm?
