Gold 2.0Si
Re: Gold 2.0Si
Post by White Exec »
Parts diags (S1 and S2) show the item as a (boot) louvre air duct, presumably clipped to the inner wing. I guess yours must have come adrift, and the one on the other side gone complete walkies.
The large chunk of foam I found is not shown on the parts diags. Perhaps an afterthought, but somewhat irregular, n'est pas?
Eddie nuff
Post by Eddie nuff »
Seems fair enough. Doesn't show up on service.citroen :?
Eddie nuff
Got a wee bit more done yesterday
The exhaust needed a little help
I'm leaving the carrier off until the welding's been done and the backing plates for the brakes are staying off until I've sorted the wheel arches out. The backing plates have come up okay and, seeing as new ones are NFP and impossible to find, are going to have to do for now
The new gear linkages are on
and ready for the little bit of welding tomorrow. :D
raynoon
Orga / RP numbers: 6043
Re: Gold 2.0Si
Post by raynoon »
All looking very nice under there! Prehaps getting the backing plates sand blasted and powder coated should bring them up lovely? Are the difficult to remove?
Eddie nuff
If I sand blasted these all I would have left would be dust on the floor.
Easy to remove, just three screws.
Re: Gold 2.0Si
Very nice.
raynoon
Re: Gold 2.0Si
Post by raynoon »
Just 3 screws? So no disconnecting the brake lines etc? 😊
Re: Gold 2.0Si
Looking very tidy under there Neil. 8-)
I must do those plates too. The jobs are stacking up again....
Eddie nuff
Ray: Jack up the car, remove the wheels, two screws at the front, one at the rear, slide the backplate out. Then, as above, rub down, two coats of rust converter, two coats of stonechip paint. Jobzagudun.
raynoon
Re: Gold 2.0Si
Post by raynoon »
Thanks Neil! It's something I've wanted to do but thought I had to take the brake pipe out too
