Ray, my car was supplied with 9 months MoT and a fine pair of rotten front sills! You are not alone. I am still sorting out the rust and mine is good car that has been garaged for most of its life!!
The garage had fitted a brand new OS front wing. The fact that they fitted it over a hole in the sill and that the bottom fixing bolt was screwed into thin air obviously hadn't troubled the bodyshop. Likewise on the NSF wing the bottom fixing tab had rotted off so the bottom of the wing was fixed to the car by a spring steel clip pushed over the edge of the wing and the sill seam.
My rear subframe is basically sound but needs droping to allow repair of one of the mounting points.
All you can do is make list, decide the best/most logical order of tasks and crack on.
Plenty of support on the forum and people willing to help out with parts and knowledge as required.
Keep the faith.
CEO 2.1turboSED auto
cxprestigeauto
Re: My XM "The Boss"
Here ray... This is how bad they can get..
viewtopic.php?f=19&t=7356&start=20" onclick="window.open(this.href);return false;
That is the correct method of fitting the bottom edge.cxprestigeauto wrote: the NSF wing the bottom fixing tab had rotted off so the bottom of the wing was fixed to the car by a spring steel clip pushed over the edge of the wing and the sill seam.
Ciaran
- Site Admin
- Orga / RP numbers: 1234
5678
91011 - Location: Ireland
That's the right attitude Ray. It just takes careful planning and effort as John says. If you're not on an urgent timeframe then you can take your time and do it right. Fair play to you for wanting to save the car, it does need some TLC for sure, but it's by no means a goner if you want to save it.
cxprestigeauto
Really! Then my OS was missing one!!!!!!Dieselman wrote:That is the correct method of fitting the bottom edge.cxprestigeauto wrote: the NSF wing the bottom fixing tab had rotted off so the bottom of the wing was fixed to the car by a spring steel clip pushed over the edge of the wing and the sill seam.
Paint code is under the crap on the chassis leg immediately behind the passenger headlight under the mass of wires around the fuse box.. In yellow and will be ---cr....
- djg
- Orga / RP numbers: 7903
This is it:
Sent from my HUAWEI P7-L10 using Tapatalk
Bye,
Gábor
Gábor
- raynoon
- Orga / RP numbers: 6043
I found the paint code on page 3. It was hidden under 23 years of grime
jonathan_dyane
Lovely looking XM in a colour I'm not sure I'd seen before. Shame about the rust but it is repairable and at least the car is cosmetically smart (unlike my XM!)
I'm in the area if you fancy meeting to compare cars and notes. My car is a base model TD but my first XM was a SED auto.
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
1986 MZ ETZ 250
- raynoon
Appearences can be deceptive Jonathan_dyane! It has lots of dings and will prob need a full re-spray, but it does look good after a good wash. We could host our own Cars & Coffee meet, but I'll have to put mine back together first
