Ahh, so now you tell merobert_e_smart wrote:You don't need to undo the top nuts! Just pull hard, there are little balls on the end of the bolts that snap into a plastic socket.
CitroJim's Citroens
Mark, It's tempting.. I forgot all about thatmds141 wrote:Hi Jim. If you're feeling up to it and aren't too busy there's the 'technical weekend' at Barry Annels this weekend.
I learnt the hard easy too Jim!
Excellent Jim. I swapped my entire LCD display with a new one a while ago....Along with the bulb. Works a treat, but it has highlighted I need to resolder some joins, as it does like to still scramble. Apparently I drive a lot in neutral!
russ92xmsed wrote: Apparently I drive a lot in neutral!
Me too, although in my case it's my brain that's in neutral!
At least you have a brain Jim!
That's more than a lot of peeps can claim!!
Jaap, I sometimes, actually very often, question that factcaptainhaddock wrote:At least you have a brain Jim!![]()
I've still not forgiven myself for blowing up a perfectly innocent ECU yet. If I had even half a brain I'd have not been so stupid
Except it wasn't perfefctly good for this application and forced you to fit the good Peugeot one. Some you win, some you lose. This one you won.
That's true Will and it makers me feel better about it
normantilbury
Jim, I'll Stop off at your place on my way down from Huddersfield tomorrow monday and as you are now a expert you can change mine,lol
Norman
Norman
