Oh, and replace/fix the kickdown cable; which has just snapped :-/jeastham wrote:
Outstanding issues :
Sort cold-starting issue - either air-ingres and/or dodgy Glow-Plug relay and/or GP feed wires
Top of to-do list :
Change engine oil & filter
Change ATF
Fit replacement rad-fan motors and fan-blades
Refit sunroof motor, and seal mounting thread
plus other trivial odds & sods, that I can live with
Jonathan's SED auto
jeastham
Re: Jonathan's SED auto
1993 2.1SED Auto. RP # 6084
jeastham
I know you can get cable joiners, with screw-terminals, such that you can repair a snapped cable. Any idea what they're called ?jeastham wrote:
THIS sort of thing?
This is listed as a ZF 4HP14 gearbox but it looks the same as the xm's 4HP18 cable, they say its for the xm up to R.P53-- but the xm never got the HP14 box so it may be worth having a check of the part number.
joining probably will not be successfull unless you use a big crimp as used when making fishing rigs and solder it but even then it will bind on the cam and certainly wont pass though the outer.
jeastham
Thanks. Will phone Citroen, and check the part #Dean wrote:THIS sort of thing?
I need to check how much inner-cable there is exposed, before deciding on whether to make a repair.
Barrel-clamps; that's the term I was struggling to come up with. That's the kind of thing I was thinking of. Might use the guts of a junction box; the type that come in strips, for joining electrical flex
Thanks
jeastham
Response from seller of Kickdown cable, on Ebay :
"Hi, this is for a petrol car only, not a diesel."
jeastham
I've had a look, and I reckon I can repair the cable that has snapped. There is enough of a run of exposed internal cable.
Just need to find a length of cable, preferably a long piece, with the right termination, so I only need to make one join
jeastham
Couldn't lay my hands on any steel cable, so had to make do with a wire, from some mains flex :
It'll do for now; until I can get some steel cable. If it don't; then it's the least of my worries; frankly,
That worked out nicely, a bicycle brake cable would do the job as its the same stuff with the same ends on i would think and then you only have one joiner. Tidy little bodge that
jeastham
It now has a fresh MOT, valid until mid August 2013.
Had a complete new exhaust fitted, an outer CV joint (N/S), both drop-links, and a spot of welding, behind the N/S/F wheel, where ABC tyres had damaged the sill. Had to replace some bulbs, and the indicator/horn/lights stalk. Paid £50 for the MOT, and £120 (3 hours) labour, plus a 10er for a slab of lager for the lads who work there.
Pretty pleased with that; and they've done a tidy job with the welding
Justin
Justin
£170 for a year isn't bad, and none of those jobs will need doing again any time soon.
