1996 xm estate turbo diesel parts (1.6)
southerner
Re: 1996 xm estate turbo diesel parts (1.6)
Post by southerner »
Will do Rommel I have remove the metal parts to keep the weight down, if you need them let me know and I will add them in the parcel.
Rommel
Post by Rommel »
If the metal bits are to do with how the trim strip attaches you may as well add them in as I don't think I have any!
If you're looking for a cheaper way to post them forget the Post Office- terrible value for money, try www.interparcel.com- good value and reliable.
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
southerner
the metal bits hold the air vents piping in place i will add them and the air vent pipe, the other metal parts are to do with the seat belt, Quoted £5 to £9 to Scotland, not because of the weight but the size.
I need now to find a cardboard box or a large flat bit of cardbroad to pack it and then i be waiting on the address to send to
southerner
Why is it so hard to find cardboard box/flat it fit in or make for packing
endorfin
Post by endorfin »
Got your windscreen.
PM me your address and I'll drop it off to you on Friday, it'll be around 1.30 - 2pm.
southerner
Ok done an a rough direction will make it easier. Oh take a look at the bumper and other parts that you might need silver in colour
southerner
Thank you Endorfin for bringing the screen to me, I will get that fitted just before the MOT next Feb.
normanlindley
Orga / RP numbers: Ex 98 Xm Vsx 2.1 Td Auto Silver Estate RP 7548
Huddersfield
2010 C6 2.2 Exclusive in black
Post by normanlindley »
Hi Pete,
I'm looking for the pair of complete hoses and fittings from the high pressure pump to the pressure regulator series II if they are still available and you have a price with postage and packaging as I no long live in Tilbury but in Huddersfield so cannot pop down and visit as before.
Regards,
Norman
Huddersfield Has no sunroof
southerner
I should still have all the hoses Norman, I check them out let you know the condition first.
southerner
Norman i forgot to ask you for an address to send pipe to you, its a one pipe metal from pump to pressure regulator, there are other pipes coming of the regulator and 1 more pipe that feed into the pump. let me also know which pipes you need if more than the single metal pipe.
