L592 EVN formerly J2 CXM
maxferreira
- Orga / RP numbers: RP6043
Re: My new project
don't worry, coolant will be added to the mix as soon as it's home
maxferreira
Re: My new project
garage have got started on it apparently, and yes, that is true, i drove past today and it was inside
should be back home next week all being well, and i honestly can't wait to drive it and put some miles on the old girl
maxferreira
Re: My new project
Passed it's MOT today
just going to walk over in a minute to go and collect it
Re: My new project
Wooo hoooooo
Julianw
- Orga / RP numbers: 4937
Re: My new project
Cracking news!
maxferreira
Re: My new project
£1,260 later it's road worthy
i was given my sills in a plastic bag
still, i've done around 90 miles in it and it seems to drive fine which is a good thing
maxferreira
Re: My new project
i also note the auto gear selector is quite stiff to move, wonder if that's due to lack of use?
antonioconceicao
Re: My new project
Nice to see it back on the road, the seats look almost new
Is it the cruise control the thing stinking out by the side of the steering column?
Antonio
Antonio
1992 Citroen XM 2.0l Inj
Vin VF7Y3AC0007AC9679
Virginia USA
Virginia USA
Re: My new project
Nice bag of filler...
Not so nice cost...
The auto selector is probably the cable needs lubricating.
You might be able to unhook it from the gearbox and run oil into the cable while holding it up.
I can't remember if the linkage in the transmission tunnel is exposed, if so grease it.
Not so nice cost...
Re: My new project
It is.antonioconceicao wrote: Fri May 27, 2022 8:58 pm
Antonio
Your car has the rotary lights switch mounted there.
Cruise control was meant to be the four buttons on the steering wheel, but they were then used for radio control instead, so in the '92 update the left stalk gained the lights switch and cruise was available utilising that socket.
IMHO, the rotary lights switch is aesthetically preferable.
