2 * 2.1 SD
Re: 2 * 2.1 SD
Post by xantia_v6 »
I applaud your attempts to get the car painted. I have done a handful of paint repairs in my lifetime using rattle cans and have a 50% rate of getting a decent result.
Re: 2 * 2.1 SD
Thanks. I need all the encouragement I can get... :|
Doing things back to front: after I painted the outside of the rear wings, I decided to check the inside of them, especially that the lip was actually painted. To the surprise nobody I saw a couple of rust blisters where the rear edge of the arch liner rubs the paint and the wheel throws dirt/water/slush up.
I wire wheeled the inside of the lip and the blisters and saw.
When wire wheeling the paint I was aware it would heat the metal and new lacquer, so was careful to not make it too hot...but that didn't stop me touching it to see how warm it was and leaving fingerprints in the new lacquer. :roll: :x
When reaching into the right side space was really tight and I also pressed against the perfect lacquer, causing a material imprint. :oops:
It's a good job I need to wet sand it.
The left side had some small pits and took quite some effort to remove all the rust, the right side was surface rust only and much easier.
Left side after about an hour of rust removal. I carried on for about another hour, until all the rust was removed, but have no image.
Right side
It's worth checking this area. I'm sure we have all seen Xm with rusty rear aches, especially series-2 Exclusives, due to them having foam sound deadening placed on top of the arch liner: the foam becomes soaked and causes the wings to rust badly.
I then wire wheeled again to peen the surface and applied two coats of primer.
Re: 2 * 2.1 SD
Two coats of primer and one coat of machine enamel (not shown) has now been applied. I expected to be able to second coat the top coat, but the heat was keeping it tacky.
As I couldn't paint that second top coat I went onto stripping the boot linings out.
I was already aware that a couple of the bolts holding the luggage tie down rings had seized in their captive nuts and the only way to remove them was to pull them out of the body, and having lifted the carpet saw some rusty areas.
It appears water has entered the boot, I think from the tailgate seal, which was loose in the top left corner, but it may also be the fir tree clip holding the wheel-arch liner in place has let water in.
This clip goes through the wheel-house from outside, behind the upright strengthening plate and is almost directly below the sunroof drain tube. More sunroof joy... :lol:
Alternatively the light seal has been leaking, but so far I think it's the tailgate seal.
Any water that enters the boot sits in the soundproofing felt and liners, so causes corrosion.
The worst area by far is the spare wheel carrier screw support. I think this is from water thrown up by the rear wheels.
So far I've given them a quick wire wheeling.
Re: 2 * 2.1 SD
Two coats of machine enamel went onto the rear wings, inner side.
I then set to cleaning up the rusty spare wheel support screw recess, which is the most affected area in the boot. I also hammered the captive nut metalwork back to flat.
Using some rubber, I plugged the hole to create a dam for the acid and gave it a scrub.
Lots of chipping with the engraver and acid washing.
Eventually gave metal that is free of rust.
There are five individal pin holes, where I have been able to push a pin through when digging the rust out and will weld up, but otherwise it is now rust free...apart from flash rusting while washing the acid off.
I need to smooth the surface as the engraving tool leaves it a bit rough, which is why water sits in the dips and causes flash rust.
Re: 2 * 2.1 SD
As soon as I touched the metal with the welder I knew it was too thin, so decided to cut out the recess and make a new one.
After cutting it out it revealed the underneath, reinforcing had some corrosion, but I cleaned that up and it's definitely sound metal.
It would have been quicker to drill out the spot welds and make a new reinforcing plate as well, but having already painted the underside of the boot floor, I'm trying to reduce welding. Also the hole in this plate will make a useful template for the upper recess section.
I do need to weld the reinforcing plate as I cut into the right side while cutting out the upper plate. :|
Re: 2 * 2.1 SD
I welded the cut flange, wire wheeled, treated then primed and top coated the strengthening plate and surrounding bare metal to stop corrosion while awaiting the new metal being welded in.
I then had ago at forming a piece to insert. This piece is dished to accept the head of the spare wheel bolt under the boot carpet.
I found a ring to use as the outer diameter, which was a piece scavenged off a broken kitchen breakfast bar stool, I then found a suitable socket to use as the inner diameter.
My intention was to use a vice to press the metal into the outer diameter ring, using the inner diameter socket.
I taped the ring and socket to the metal to keep them centered and tightened the vice. This did press the socket in, but due to the metal plate not being held fast, it buckled and created a fold, which couldn't be removed. Due to not being able to paint the rear side when this is in position, I have chosen to use 1.2mm stainless steel, as opposed to 1mm mild steel. Stainless steel is harder to manipulate and work hardens readily, so removing that fold wasn't an option.
I cut another piece of the same steel and chose to simply drive the socket into it using a lump hammer, which allowed me to see when the plate began to buckle. I then worked the plate to remove all buckling, then carried on hammering the socket in, which allowed me to reach approximately 50% required depth, however it was a little off centre.
I then resorted to using my small ballpein hammer and hammer forming the rest. You can just see witness of where I used the hammer and re-centered the inner ring.
Re: 2 * 2.1 SD
I worked the recess to reduce the hammer marking. It took me a while to think to use a form of dolly for the inside. I ended up using a large socket, which really helped, as it gave a smooth mass to hammer against. I could probably have gone further, but time was running out.
I then cut the metal to shape and hammered the end flange over to match the boot floor pressing. I filed the sides to centre the new metal cup with the reinforcing plate.
Re: 2 * 2.1 SD
I needed to make a 20mm hole in the base of the cup, for the spare wheel carrier screw to pass through, but the largest twist drill bit I have is 13mm.
I centre punched and drilled a small hole which went off centre, so brought it back to centre using a small, pointed, carbide Burr.
I then drilled out to 13mm and tried using a stepped drill to drill further, but it wasn't able to drill the stainless, so then fitted a straight Burr into my bench-top pillar drill and by hand gradually enlarged the hole to 20mm, finishing by hand filing and a rub with Wet & dry paper.
I checked the nylon bushing was able to pass through the hole and the hole in the plate aligned with the one in the reinforcing plate.
I then cleaned off the paint where the new metal was to be welded into, installed it, checked for alignment again, tested there was sufficient clearance for the wheel brace foot by using the screw to hold the spare wheel carrier with a wheel installed.
Being made of stainless means even if the wheel brace foot catches the side scoring the paint, it won't rust. It's also stronger than the original plate.
Re: 2 * 2.1 SD
I started the painfully slow task of removing rust from the spots in the boot, the first area was quite large and in an awkward area just inside the tailgate opening on the upright section, where the luggage tie-down is bolted.
After lots of chipping, scrubbing with acid and picking with a pin, it was finally clear of rust.
I've only managed to clean a fair selection of spots, but all came good and one was an awkward spot that had crept under the seam sealer at the edge.
I was concerned the rust might creep down inside the joint so scraped off the seam sealer and really worked at it.
I believe water has been entering the boot due to the seal at the top left corner having come unclipped from the gutter, which then allowed water under the seal and to drip into the boot.
The inside of the boot is only painted in primer then top coat overspray, so doesn't really have a lot of protection.
Re: 2 * 2.1 SD
I made a start on the boot side reinforcing plate, which has some surface rust.
A single dose of acid and scrubbing with a small wire brush took it from
to
Being thicker steel I can use the engraver directly on it, but it's still a very slow process.
