..to put it back you need one zip tie, on which you need to take off the clip, push it into the slot and it will hold the expanded brushes while the engine is being returned, then just pull out the zip tie and the brushes are returned to the rotor.
...motor returned to its city.
..it should be taken into account when assembling the transmission, the gears, that these two arrows on the gears are aligned so that everything works as it should.
..at the end, assemble everything and return it to its place, for now everything works and functions.
Gasa XM 2.1 "Prestige"
Gasa
- Orga / RP numbers: BX 1.9 TRD
Re: Gasa XM 2.1 "Prestige"
Gasa
...friend Emil from Bulgaria-Sofia visited with his DS 21 in 1970.
- Jan-hendrik
Excellent work and description. Only your zip tie is a safety pin
Agreed, good work and write up. For when it finally becomes necessary, you can buy those motors online, I believe they are the same as central locking motors.
Your friends Ds must be one of the last with thin steering wheel and push button outer door handles.
Gasa
..but now it's easy to find another engine, you can put the engine from moving the flaps to direct the air, the problem was to establish the fault due to the fact that the heating does not work, now it is much easier to eliminate the fault.
Gasa
...today's ride was number 2
That upper image looks photoshopped due to the panoramic windscreen.
Gasa
another registration extension was completed, the technical inspection was completed without any problems.
The exhaust gases are good, the final test is 0.06 the limit for these older diesel engines is 2.40
Gasa
I don't know what the problem is with the thermometer, I bought a new sensor, measured the connections between the sensor and the connector on the door, everything is fine, the contacts are good, I don't know what's wrong with it.
at the moment the engine was turned on, the temperature was exactly +21 degrees, after a few minutes it started to reduce the temperature and in the end only lines appeared.
--- indicates no connection, so it's possible there is a poor contact between the display and temperature sensor, alternatively one, or other is duff.
Try plugging a temperature sensor directly into the display.
