Mk2 C5 buying advice
kingp
Re: Mk2 C5 buying advice
Post by kingp »
They are but the Mk 2 Doesn't have the hdi 110 2 Litre engine But the 136 bhp_engine But Both Can take the solid Flywheel From the older PSA vehicles using the 110 engine variant which is good news going forward for everyone :)
ekjdm14
Orga / RP numbers: 6470
Post by ekjdm14 »
Oh dear, so Citroen were plagued by the Goddamit engine too then! Thought it was restricted to mitsi and Volvo that suffered those motors. From what I've read in Volvo circles the earlier version was not QUITE as troublesome, and the gumming up issues were largely reduced by driving hard as opposed to babying it for economy (don't think economy was all that affected by harder driving either). All in all it was known as an engine option to avoid, but if you found yourself lumbered with one then you could usually manage the faults by a combination of shorter oilchange intervals, heavy right foot and mostly, cleaning the intake/throttle body etc thoroughly at the start.
Post by White Exec »
EGR responsible for inlet clag, loss of a couple of a couple of mpg, and sometimes full-throttle hiccups. Easily sorted, albeit with some NOx considerations, for the small number of who do.
DMFs have hit almost every diesel (and a couple of petrol, apparently) engine since the late '90s. Also sortable, thank goodness.
