Mark's XM.
dollywobbler
Re: Mark's XM.
Post by dollywobbler »
Ah, I think my driver's door is also leaking. Mats seem damp and there is water on the sill lip. After rain last night, the passenger side was still dry at least!
1986 2CV6 Dolly, 1980 Dyane
mds141
Orga / RP numbers: 8542
Re: Mark's XM.
Post by mds141 »
T30 Torx bit on the door strike plate Ian.
Mark Smith.
1997 Honda Firestorm.
Re: Mark's XM.
mds141 wrote:In the absence of a hair dryer, I might have to wait until June. :-)
What about hot water. Maybe not boiling, might shock the plastic. Or a hot damp flannel or towel.
If that works, you need to push down and prise the bottom out. It will crack, as in a noise, not break...hopefully, and then it lifts off. Many though have different techniques on how to get them off. But I have not broken one yet..... He says. :lol:
mds141
Re: Mark's XM.
Post by mds141 »
I was going to ask about the Club XM approved method of removing the trims. I've done it once and have been in therapy ever since. :-)
Mark Smith.
mds141
Re: Mark's XM.
Post by mds141 »
Despite the adjustment to the passenger door and parking on level ground I'm still getting water ingress. Until I can get to the scuttle area, I've treated the 'ol girl to a car cover. Actually it was an early birthday present from my mum & dad.
Mark Smith.
dollywobbler
Re: Mark's XM.
After further sunroof bodgery failed, I may have to resort to similar measures! I've got a 2CV-sized cover. Should cover most of it...
Re: Mark's XM.
Very good idea. :)
mds141
Re: Mark's XM.
Post by mds141 »
I bought an extra large cover from Halfrauds and it's a good fit. Not too tight or too loose.
Mark Smith.
Re: Mark's XM.
dollywobbler wrote:After further sunroof bodgery failed, I may have to resort to similar measures! I've got a 2CV-sized cover. Should cover most of it...
Just whip the glass out and rebond it, an afternoons work.
mds141
Re: Mark's XM.
Post by mds141 »
I think Ian is waiting until some dry weather appears. Which it does occasionally in Wales.
Mark Smith.
