First ever Citroen
Re: First ever Citroen
I like the mix of the checkered velour door cars and black leather. It's looking very tidy indeed.
Is your XM mandarin or magenta? (The paint code is in the engine bay in front of the battery on the wheel arch.)
HooXM
Post by HooXM »
Thanks for the feedback Russ. The guy I bought it off said it is Magenta.
I cleaned out loads of muck from the drivers side lower wheel arch behind the plastic cover. No holes in the sill thankfully :-)
George
Xena - 1995 XM 2.0 Turbo Exclusive - Magenta
S2 cars were never in mandarin, your car is definitely magenta.
HooXM
Post by HooXM »
Had a rather bad XM day today. Took the car for tracking and wheel balancing as he front end was a bit light. Near side track rod end barely attached to the steering rack! Car better now but a look underneath revealed that the chassis leg end where the back box hanger is is rotten and we have very leaky hydraulics under the bonnet.
Also took a couple of pics while the front wheels were off for balancing and it seems some tiny pipes are broken
An urgent trip to Medway Citroen needed I think
George
Post by xantia_v6 »
I think the broken "pipes" might be the brake pad wear sensor cables.
HooXM
Post by HooXM »
Phew and fingers crossed
George
HooXM
Post by HooXM »
I am also wondering if the hydraulic leak has anything to do with the brake fade the suffers with. Anyway, I got a price on the two rear exhaust boxes too which comes to nearly £300.00
George
Rommel
Post by Rommel »
Goodness me, you could have a bespoke stainless steel system made for barely more than that!
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
