I've joined the XM lifestyle
ahmadmarfy
Orga / RP numbers: 4777
Re: I've joined the XM lifestyle
Post by ahmadmarfy »
Citjon wrote: Fri Aug 25, 2023 1:38 pm I know of a 1992 2.0si with single fan front panel, which is for breaking.
I'm not sure if the fan loom is still there but will have a look if needed. I've also got an inner rear screen with fixings if you're still looking for one.
Cheers,
Jon
Nice to meet ya Jon,
Whatever you can find will help my precious xm,
I’ll take it 🤝
ahmadmarfy
I’m trying to get my car ready for the 8th of September. Wish me luck
ahmadmarfy
Cheers,
Jon
Also Jon if the cars breaking, have you got an middle silencer for the exhaust and and is there the trims I could probably use for the dash, side trims and also the seats if they’re romana?
Citjon
Orga / RP numbers: 8032
Post by Citjon »
I don't think it has an exhaust, have you tried ebay? There were some listed for around £60 last time I looked.
Which trims do you need for the dash? I can probably help with those. The seats are Sonata unfortunately.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
ahmadmarfy wrote: Sun Aug 27, 2023 9:07 am I’m trying to get my car ready for the 8th of September. Wish me luck
I'll be there Sunday 10th which is usually the busiest day.. 8th and 9th are quieter days.
ahmadmarfy
Yeah i need the car parts by monday if I really want to get it sorted ah, otherwise i'll just have to tag along at the show. will update abut which parts i need in the car around 17:00 with photos hopefully.
I could only find a couple of suppliers with middle silencers on Ebay. Other suppliers appear to have no stock, but it doesn't mean they can't obtain them.
https://www.ebay.co.uk/itm/325602535848 ... p_homepage
https://www.ebay.co.uk/itm/185206281628 ... p_homepage
Same supplier, no delivery.
https://www.onlineautomotive.co.uk/car- ... T3026/1/38
Try ringing round your local parts suppliers, from memory, Parkers at Foundry square used to supply a lot of exhausts. 0116 242 8200
If you car has the original single piece exhaust it will need to be cut and have fittings added, or cut the flares off the new part and sleeve both sections.
If sleeving, it's best to weld the sleeve to one of the sections to make it a socket (downstream one works best as it captures the gas-flow), otherwise it will tend to sag at the joint.
A local welder, or exhaust centre should be able to weld on the correct joints for the new part to mate up to. It might even be worth approaching them for supply, but one would normally expect a mark up on price.
Degens
Post by Degens »
I have a headlight if you need one. I am in Alsager, close to Crewe
ahmadmarfy
Evening Everyone, or morning/afternoon if you’re reading it at that time.
Anyways I’ve started once again on this journey. It got sort of delayed due to personal circumstances and the very cold weather. Well I’ve decided to get my hands dirty, today I learnt how to change the handbrake cable and the flexi hoses. A month ago I got the ignition switch changed from the bodged up ignition button.
2 months before that I luckily received the key from the previous owner. I was most pleased.
Anyways now if @Citjon is reading this, the 2.0si that was broken for parts, I wanted to inquire if there was any intention to give the car away as a whole, if so I would be very pleased to take it and collect it.
@Dieselman has given me some advice and visited me, and guided me in my quest to getting my XM back on the road.
I need a good few parts,
- regulator with pin for housing
- radiator temperature fan loom
- return LHM pipe set
- Alternator
- inside plastic trim
- middle silencer
Let me know what you can do. I’m trying to get the car ready for the events soon.
Well that’s it from me folks,
Until the next post : )
ahmadmarfy
Degens wrote: Sun Sep 03, 2023 8:25 pm I have a headlight if you need one. I am in Alsager, close to Crewe
Hi there , do you still have the headlight available? Is it right or left?
