Hello Chaps....new owner
Stickfinger
Re: Hello Chaps....new owner
Post by Stickfinger »
Ye3s, all the bits (cam pulley is here, belts tension wheels) are here or arrive by the weekend......I hope to have it started next week.
I have a LHM pump union seal to do as well....but it is only a weep but needs to be done before it destroys the alternator.
Those 6 and 2 pump are same as xantia .. the large. O ring gives on the suspension output.. not a too bad a job to do not sure where else other then dealer you can get the O ring from..
The O ring is probably cheap enough from the dealer, but any seal stockist should be able to supply one of the correct size.
Yes course. But you know as well as me it will become nfp .. the last lhm cars using this type of pump is now 20 years old..
Post by White Exec »
Parts diagram...
Stickfinger
Cheers...
Stickfinger
Bits coming in one at a time :)
Stickfinger
bugger I ordered the wrong tensioner......re-ordered the correct one
Stickfinger
Ummmm, this did not help things :)
Nasty!
