K-BAN has a new home
Re: K-BAN has a new home
What you need is a 3' x 2' sheet of galvanised steel, a drill, mastic and pop rivets. That made a very effective fix when my FIL's Montego sunroof glass blew out while driving along. Not a drop of water ever entered the car.
- raynoon
- Orga / RP numbers: 6043
Right... Today... In sheer frustration at the bloody thing I went into overkill mode. I've silicon' the bloody lot.
I'll leave it to cure now til Monday.
Well if that doesn't get it.....
- raynoon
Ok, I went after work and fitted the cassette, it was a bit tighter this time and took some fettling, then the hose pipe came out.
Then I took it up and down the Motorway, went to my friends house, gave a lift... Basically drove around for 90 minutes in the rain. I'm home now and I'm not wet. Not even damp. Don't mention the "L" word. It hasn't happened yet.
Okay. But yay!
cxprestigeauto
Sounds promising.
Russ, keep quiet!!!!
- raynoon
I'm still not wet...
It's not raining
- raynoon
We've had torrential downpours and hail over the past couple of days, I think (hope) I've sorted it now so I've started re-fitting the headlining and trim
