Rob's SED Now V6 Exclusive
Re: Rob's SED
The sensor in the light unit, cylindrical thing.... has a small fan in it. You can see the little blades. They get coated in fluff and dust, as I'm sure you have found out. I did exactly the same thing today too. I also squirted some WD40 in it too help it out!
Re: Rob's SED
There should be a small fan unit mounted above the light unit.
- ragger
Re: Rob's SED
I realise I am quite possibly being dense, and I apologise for that, but this is what is sitting between the lights: and it's not cylindrical and doesn't seem to move.
Do I need to remove the housing to get in behind the little grill?
Edit: Sorry the picture went, it should be back now. I think it is probably a sensor for the alarm that was fitted by the dealer at point of sale.
Re: Rob's SED
Yes.
- ragger
Re: Rob's SED
Thanks!
So what is the green block with thge sticky down bits?
Re: Rob's SED
Yeah that's it, drop the whole lot down. It sits in between the light contacts, above the round grill, and it simply pulls out. It's like a cylindrical tube thing with a fan built into it.
I think Beko has has just cleaned his today. So there are some good pics of the sensor.
Green block. No idea. Your photo doesn't appear to work.
Re: Rob's SED
Ah...the green thing might be the remote locking receiver. I don't have one so not sure what it looks like!!!
Re: Rob's SED
It is the remote receiver.
messerschmitt owner
Re: Rob's SED
which in R267 and N477 must be somewhere else as it isn't up there in either car ...Dieselman wrote:It is the remote receiver.
Re: Rob's SED
You will find your remote receiver in the dash under the glove box.
All UK Mk2's have a RF remote system.
[/url]
