My Citroen XM 3.0 PR-Vestige
Deep shame from incompetence again.............. :lol:
Twas the balancer shaft timing, I have no explanation, as soon as I took the cover off it was obvious it was out :roll: It's times like these I question my sanity I really do.
Silky smoothness is now reinstated, now for the running issue which I believe to be fueling, either fuel injectors or pressure regulator.
Post by White Exec »
No need to apologise for the incontinence....it can happen to any of us :cry:
The good news is you found it.
You couldn't miss it, yet I did.
I think I was preoccupied with the cam timing but it was a simple job to do, rocker cover off, undo balance shaft sprocket bolt, slide balancer shaft off sprocket, put sprocket in chain in correct place and turn balancer shaft to match and stick it back together.
Damn amatures.
Post by MTXM »
That is good news you found the problem Dean and no harm done! Regards, Matthew T.
Nope no harm done and running well now, apart from the full throttle issue which i am trying to track down
https://youtu.be/N1NQX2whFLs" onclick="window.open(this.href);return false;
Your vid popped up on my YouTube recommendations last night. Have to say, it's looking amazing and sounding great. It has that French purrrr!
Thank goodness the balancer shaft timing was an easy fix. Sometimes you can be staring at things for so long, you just miss the simplest of mistakes.
russ92xmsed wrote: Sometimes you can be staring at things for so long, you just miss the simplest of mistakes.
........... Twice
misha
Post by misha »
:mrgreen: :mrgreen: :mrgreen:
........... Twice
:lol: still ....so far there hasn't been a third!
Not yet Russ no!
https://youtu.be/QME3YmXXrBk" onclick="window.open(this.href);return false;
