Bought another XM
jonathan_dyane
Re: Bought another XM
Post by jonathan_dyane »
I like no egr! I wonder if you could put up the photos of the car you have Paul? I have only seen the ones on the ebay listing...
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
Hi Johnathan,
Its only three more of the engine bay, anyway, here they are for you..
That isn't the correct manifold, the EGR has been removed.
The engine is a replacment, obviously it has been replaced with an earlyer engine and prehaps had the Bosch setup swapped across...
jonathan_dyane
Thanks Paul! The Bosch setup always came with egr then?
Jonathan.
1986 MZ ETZ 250
Post by captainhaddock »
Congrats! Does that mean the Dyane is going now? Be careful you might get hooked driving those XM's! Wish you luck with it, add some photo's why not!
Interesting about the manifold and Bosch thing. Mine has Bosch and no EGR, it's a June 1992 car. Therefore Plastic manifold fitted. Charles's 2.1 which was built on the same day as mine, has EGR I think ( could be wrong there... Paul, you fixed it up , you'll know!! :lol: ) with the metal manifold and Bosch. However the difference is probably down to mine being an auto and his being manual. There is nothing in my cars history to suggest an engine swap or manifold swap.
djg
Orga / RP numbers: 7903
Post by djg »
Citroën on the web can tell you what it was fitted with originally, although this info is in the subscriber section, I'm afraid. Still, you get one hour for 5 euros and you can download anything during that time. It might be worth it. Unfortunately, schematic diagrams are not available for the XM there.
Bye,
Gábor
russ92xmsed wrote:Interesting about the manifold and Bosch thing. Mine has Bosch and no EGR, it's a June 1992 car. Therefore Plastic manifold fitted. Charles's 2.1 which was built on the same day as mine, has EGR I think ( could be wrong there... Paul, you fixed it up , you'll know!! :lol: ) with the metal manifold and Bosch. However the difference is probably down to mine being an auto and his being manual. There is nothing in my cars history to suggest an engine swap or manifold swap.
Auto cars didn't get EGR initially.
Thank goodness!....after your description on Sunday Will about undoing the bolts at the back of the engine.
