Waiting for the AirCon man
Re: Waiting for the AirCon man
LOL.. :D
A good job too as a high rise OAP bungalow could make life awkward.
Post by Peter.N. »
I have a trench nearly 200 metres long which carries the water up from the well, I thought that might be ideal for a ground source heat pump but I think its highly possible that it will freeze my water supply - no John, I haven't filled it in yet but I am about to.
red_dwarfers
Post by red_dwarfers »
I'm a bit of a novice when it comes to heating and things. How do they dig that far into the ground 330 is quite a way down!
Peter.N. wrote:I have a trench nearly 200 metres long which carries the water up from the well, I thought that might be ideal for a ground source heat pump but I think its highly possible that it will freeze my water supply - no John, I haven't filled it in yet but I am about to.
Didn't you say that last time I was over yours? :lol:
'07 C5 2.0 16v HDI VTR estate
'81 GSA 1.3 Club
red_dwarfers wrote:I'm a bit of a novice when it comes to heating and things. How do they dig that far into the ground 330 is quite a way down!
They sink a borehole.
Although using a depth of 1m below the surface is good as it captures solar gain, why not use the well as the heat source. Drop a pipe right tot eh bottom and collect the heat from the sub strata.
Hi Kevin
Digging the hole is easy.
At any depth you only dig a spade depth at a time.
Chucking the muck out from 330 feet down needs real skill.
If the rain stops you could always practice in Peters well.
Post by CitroJim »
xmexclusive wrote: Chucking the muck out from 330 feet down needs real skill.
Dad tells me they brought in a proper drilling rig to dig his.. It was lubricated with copious quantities of water and it made a right mess... A red mess - the colour of the subsoil. It took about a day to drill each borehole even with this purpose made rig...
Post by Peter.N. »
Unfortunately the well is not that relaible, it went dry this year until July, its had loads of water in it since then but its only 25' deep.
