Citroen Mechanic in the South West
Re: Citroen Mechanic in the South West
As you have moved from France, it is worth asking if it is a LHD or RHD car?
The car is LHD, so no bell-crank.
I think a hydraulics flush will fix the issue.
It's easy to do. With the car at the lowest height empty the hydraulic reservoir and clean it out, clean the filters, fill with Hydrarincage, drive for 3000 miles, drain and fill with new LHM.
To ensure the flush has reached the brake calipers, bleed the brakes.
https://www.gsfcarparts.com/980pc0130
The flush is available from other sources.
Flushing hydraulic systems is common practice in industrial applications, so flushing oils should be available from hydraulic oil suppliers.
Worth reading.
https://www.machinerylubrication.com/Re ... lic-system
Worth reading.
I've just last week had 5L of H'cage from Citroen here, to replace my spare - €27.
Here is WhiteExec's original post regarding Hydraflush at Citroen dealers. There is no guarantee that Citroen dealers in the UK can obtain this via the UK concessionaire.
White Exec wrote: Fri Oct 05, 2018 3:47 pm Just for info, this is Citroen's part no. for Total Hydraurincage, 5-litre
11350 01 Hydraulic suspension/steering fluid
...further described in Parts as System Cleaning, Total Hydraurincage
Might help with Cit parts counters that claim not to have heard of it, or that it can't be found.
Betweenthewheels
Thanks for that Chris - very comprehensive.
Will print off this great advice and bring in with me on Friday. Car booked into Salters in Devon as recommended. Will update here when sorted out. Thanks again.
Ultan
Ultan
Taunton, Somerset
Currently: Citroen XM V6 24v 1998
Saab 900 Turbo 1991, Volvo XC90 2012
Previously:
Citroen XM VSX 2.0 Petrol 1998
XM Series 1.5 Prestige 1994
CX Prestige1987
CX Pallas 1978
SM 2.7 EFI 1973
DS Pallas 1971
DS carb 1968
Previously:
CX Prestige1987
CX Pallas 1978
SM 2.7 EFI 1973
DS Pallas 1971
DS carb 1968
DerekB
- Orga / RP numbers: PRV V6 auto LHD 6751
I recently bought Hydraurincage from here
https://shop.citroenclassics.co.uk/hydr ... s-51-p.asp
Derek
1995 XM V6 LHD Diravi Blue
2007 C5 Exclusive Estate
Good to see a UK stockist of it, even if top price. Not easy to find these days.
I suspect it is similar to most other mineral based flushing oils, which are often kerosene based and widely available.
It's LHM with some added solvents.
Total's MSDS sheet has the composition.
