S1 vs S2
Kerry CX
S1 vs S2
Post by Kerry CX » Mon Mar 06, 2017 12:24 pm
Hi guys. I have a very good 1992 2.0i Prestige Auto. A 1997 2.0i Manual has come up for sale with a broken timing belt here in Ireland. Would it be worth my while buying it for parts or is there a lot of parts not compatible. Would the gearbox fit if I decided to change my own to manual at some stage. Thanks in advance for your help.
Sent from my iPhone using Tapatalk
Re: S1 vs S2
Post by Dean » Mon Mar 06, 2017 12:50 pm
The gearbox might be the same if its not a TCT but the engines will be totally different, chances are its a TCT (turbocharged version of your engine) but if it is normally aspirated it will be a 16v motor and totally different engine to the one you have in your prestige.
Re: S1 vs S2
Post by citroenxm » Mon Mar 06, 2017 4:42 pm
Tct still sold in 1997? Thought it had been binned by then..
Re: S1 vs S2
Post by Dean » Mon Mar 06, 2017 5:03 pm
I'm not sure, I thought it went to the final hour?
Kerry CX
Re: S1 vs S2
Post by Kerry CX » Mon Mar 06, 2017 7:27 pm
Thanks for the info. I'll leave it be.
Mike
