Does anyone know the part number for the 70mm lower rear engine mount? I've found a lot but they are listed for different models and engines and I want to get the right one for my 2.0i, ive bought one before and it transmitted a lot of vibration so I suspect they produced different compounds of rubber.
Could someone with access to service citroen have a check on the right part number for me?
Engine mount part number
Re: Engine mount part number
Hi Dean,
1807 68 until RPO 06293
1807 A3 since 06294
Both of course NFP!!
1807 A3 since 06294
Thank you Paul.
The part numbers above have also vanished without trace but it would seam there are only 2 70mm lower mount bushes one has a circular alloy core, the other an oval alloy core, I believe from my searches the oval cored version is the alternative O/s engine mount and the round one the lower mount, many many part numbers are bounded around for the same item depending on the vehicle and manufacturer (pug or CIT) but I believe I now have the right one so thanks again Paul.
