VIN numbers
VIN numbers
Post by Dieselman » Mon Mar 14, 2011 8:35 pm
I have been checking specs of cars according to VIN number and have 2.1td sorted as to the sequence, but can't work out the other engine variations.
Is anyone prepared to put their VIN up, or send it in PM so I can work out the sequence and build dates.
What is interesting is that contrary to popular belief, going by numbers I have checked so far, XM diesels didn't sit around a long time before being registered, it was normally only a few weeks from build date to UK registration.
three examples so far are:
  • Build 5.09.90........ 2.06.92....... 15.06.92
  • Reg 5.10.90........ 28.08.92....... 28.09.92
What is also available, but not on early cars, is the equipment the car came with. Interestingly it appears all the S1 cars I checked had antilock brakes, s1.5 didn't initially.
Here is how the VIN is laid out.
VF7Y*AF****AF****
My understanding is the VF7 means Citroen.
Y3 or 4 means Series-1 or Series-2
The first four **** are the model type,
the last four **** are the number in the batch (maximum 9999)
Re: VIN numbers
Post by robert_e_smart » Mon Mar 14, 2011 9:08 pm
I used to create VIN numbers when I worked for the trailer manufacturer. I can't remember now how it works exactly, I think the VF is for France VF7 = Citroen, some of the letters were used to designate manufacturing plant, the year of production, and the cars production sequence number, eg the 3456th built etc.
But to get the ball rolling.
VF7Y3AT0002AT---- - I don't know the RP number.
2.1 Turbo SD Estate Automatic
VF7Y3AX0000AX---- - I don't know the RP number.
2.0 TCT Prestige Auto
2.0 TCT
VF7Y4NW0000NW---- - RP 6654
2.1 TD Auto Estate - reg 31/3/95
VF7Y4NX0000NX---- - RP 6387
2.5 TD - reg 17/6/94
Edited: Production sequence number removed.
Last edited by robert_e_smart on Mon Mar 14, 2011 9:39 pm, edited 1 time in total.
Re: VIN numbers
Post by xmexclusive » Mon Mar 14, 2011 9:28 pm
You are right about the Y3/Y4 being Mk1/Mk2.
The type code is the two alfa numbers.
AE = D12 Car : AS = D12 Estate
AF = Turbo D12 Car : AT/AU = Turbo D12 Estate
CU = V6-24v Car
CM = V6 Car : CN = V6 Estate
CH = V6 Car : CJ = V6 Estate
AX = TCT Car : AY = TCT Estate
AH = 2.0 Injection Car : AR = TCT Estate
AZ = 2.0 Injection - Car France only slugged to drop CV rating by 4
This is from the 1994 Model year book.
I have the same information for all subsequent model years.
I also have the detailed breakdown of the VIN coding somewhere.
It is not a good idea to put actual VIN's up on a website.
Reg No and VIN is all you need to apply for a replacement V5 which DVLA are happy to send to a new keepers address.
On this point I think we should also drop the members birthday listing from the forum for security reasons.
Re: VIN numbers
Post by Dieselman » Mon Mar 14, 2011 9:48 pm
I didn't expect the first numbers to be all zero's...
VF7Y3AT0002AT****
ORGA...06044
5 DOOR ESTATE
4HP18
ENGINE XUD11ATE
FUEL SUPPLY TURBO-INJECTION EXCHANGER
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 19-5 DEPOLL (ENGINE)
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
UPHOLSTERY COLOUR "FR"
RIGHT HAND DRIVE
VF7Y3AX0000AX****
ORGA...06069
UPHOLSTERY COLOUR "FY"
ENGINE TURBO INJECTION XU10J2TE
DRIVING POSITION RIGHT HAND DRIVE
REFRIGERANT FREON R12
VF7Y4NW0000NW****
ORGA...06652 (Note)
INTERIOR TRIM TYPE L005 "C2" LEATHER"
GEARBOX (CHARACTERISTICS) BVA 4HP18
ENGINE (TYPE) XU/XUD
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
TRIM LEVEL LEVEL VSX
CATALYTIC CONVERTER WITHOUT CATALYST
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 21 X 75
TYRE (SIZE, TYPE) 205X65X15 V TYRES
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 22,5
STEERING UNVARIABLE POWER STEERING
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 25
HYDRAULIC PUMP 5 SUCKERS PRESS PUMP
REAR SUSPENSION SPHERE UPPER REAR SUSPENSION SPHERE
FRONT SUSPENSION SPHERE UPPER "NOK"
MAIN ACCUMULATOR SPHERE UREPAN ACCUMULATOR SPHERE
WASHER JET WINDSHIELD WASHER JET WITH DEFROST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REFRIGERATION AUTOMATIC AIR CONDITIONING
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL SPORT LEATHER STEERING WHEEL
PARTITION WINDOW WITHOUT SEPARATION GLASS
SIDE IMPACTS DOOR WITH REINFORCEMENT
REFRIGERANT REFRIGERANT LIQUID R134
There is loads more info for this car...^^
VF7Y4NX0000NX****
ORGA...06387
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL EXCLUSIVE
ENGINE TURBO DIESEL DK5ATE
TRANSMISSION BVM5
INTERIOR TRIM TYPE DIAMANT VELVET "K8"
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 16 X 65
CLUTCH ASSISTED HYDRAULIC CLUTCH
WHEEL (TYPE) ALLOY WHEELS
CRUISE CONTROL SPEED CONTROL
Again, a lot more for this car.
If you want me to completely edit the VIN numbers let me know.
Re: VIN numbers
Post by Dieselman » Mon Mar 14, 2011 9:52 pm
xmexclusive wrote: I also have the detailed breakdown of the VIN coding somewhere.
Thanks for that John, it all makes sense now.
I agree about not showing full VIN details and have edited accordingly. If they need further pruning let me know or a Moderator can do it.
Re: VIN numbers
Post by robert_e_smart » Mon Mar 14, 2011 9:52 pm
Where are you pulling this information Will?
Service Citroen? They give details on everything when you enter in the VIN number.
Re: VIN numbers
Post by Dieselman » Mon Mar 14, 2011 10:05 pm
robert_e_smart wrote:Where are you pulling this information Will?
Yes, from Service Citroen. I only found the correct link to use today, but it is useful for checking what a car has or is.
Put the VIN in and use the characteristics link on the left.
From what I can glean, mine and Pauls are possibly the oldest RHD diesel XM. I can't find any showing as older even by changing the build number unless anyone knows of an older one.
As I mentioned earlier, the RP number doesn't guarantee the car VIN number will be in sequence.
It appeared that some cars were pushed ahead for whatever reason, maybe parts supply for certain trims or maybe to fulfil customer orders instead of stock.
kenhall
Re: VIN numbers
Post by kenhall » Mon Mar 14, 2011 11:09 pm
It probably meant they were registered first to a Citroen dealer rather than a customer. My 2.1TD sat around somewhere for a whole year betweem DOM and first UK registration.
Ken
Re: VIN numbers
Post by Dieselman » Mon Mar 14, 2011 11:48 pm
Not he three I checked earlier, I don't believe any of them were dealer demonstrators. My own car was registered to the single owner that had it before me.
I wish I still had the VIN's of the two I had from new. I'm pretty sure the first one was an old stock car, but the later one was built to order.
Re: VIN numbers
Post by citroenxm » Tue Mar 15, 2011 8:25 am
ALSO Will Not ALL S1's had ABS...
Ive got a Manderin S1 on a J 1991 Plate, Turbo D base with NO ABS :D :lol: (This Model is here with me in works car park)
My first XM though, was a 2.oi Base, that did have ABS though..
Also IIRC correctly a year or so ago I went to see another white Base Turbo D XM in white, that also didn't have ABS...
I think the DERVs didn't sit for long as they were bought by companys, and were also appealing back then for the XUD 11 excellent MPG (Remember it was 1990 so it was around 70ppl..) and high refinement.
I remember the "Book Club" came to our works about 10 years ago, and he pulled up in a Manderin XM SED... I wasn't into them quite so much as now, but drooled..
