Xm 3 0 170 hp 1994 automatic .brakes issue
ronenengel
XM newbie
Post by ronenengel » Mon Jan 08, 2018 4:37 pm
Hi for all.
I bought this car for a project to work with my boys.
They are not happy with this so.....im on my own.....
The car was standing for 18 month and no trittmen at all.
I fixed alot but.still ther is along way.
Im traing to take out the air from the brake's
At The front wheels.i took out the air by relis the screw untill the liquid will go out but the pedal is strong.
At the rear wheel it is imposiblle.any ide?
there liquid is no going out and the pedal us strong....
Please help.
Thank you
Ronen
Re: Xm 3 0 170 hp 1994 automatic .brakes issue
Post by Dean » Mon Jan 08, 2018 5:57 pm
The rear brakes are fed with fluid from the rear suspension, the more weight on the back axle, the more pressure in the rear brake system and the more effective they are, you must bleed the rear callipers first with the car set to maximum ride height, this puts full pressure into the rear brake circuit even when the car is on axle stands which can then be bled through, i take it you have the car on axle stands with the suspension left on normal ride height setting? there will be no pressure to the rear callipers like this.
Also do not forget to bleed the ABS hydraulic block first, this is accessed by taking the n/s wheel of and n/s arch liner out, there are two bleed nipples on top of the ABS hydraulic block if it is a Bendix system.
For bleeding all brake callipers and ABS block just set to maximum ride height, support on axle stands, wedge the brake pedal on with the engine running, remove wheels and work you way round, starting from the abs block, then o/s/r, n/s/r, n/s,f, o/s/f callipers
Good luck with the project!
Post by Dieselman » Mon Jan 08, 2018 6:58 pm
ronenengel wrote: I bought this car for a project to work with my boys.
Have you considered trading them in for new Sons?
ronenengel
XM newbie
Post by ronenengel » Mon Jan 08, 2018 7:44 pm
Hi
Thank you for the respond.
Ill do it first thing in the morning.i hope that im in the last issue........
And........english is not my language so im traying to find defarent words thet will have the same meaning......sorry.
Again.thank you.
Ronen
Post by White Exec » Mon Jan 08, 2018 7:51 pm
We can follow what you are saying, so no real problem, Ronen!
Post by Dieselman » Mon Jan 08, 2018 10:30 pm
Your English is OK...no problem understanding what you are saying at all.
Change your Boys for two new ones. ;)
ronenengel
XM newbie
Post by ronenengel » Tue Jan 09, 2018 3:46 am
:D👍
