Spare Wheel Carrier
Six-cylinder
XM newbie
Spare Wheel Carrier
Post by Six-cylinder » Tue Feb 12, 2019 10:05 am
I have just bought my first XM and need a spare wheel carrier.
Can anybody sell me one please?
Just good enough to stop the wheel falling out is fine.
1997 XM 2.0 16v Auto SX
Re: Spare Wheel Carrier
Post by citroenxm » Tue Feb 12, 2019 11:25 am
Ahhh it's you on fb Chris.. I have replied over on Facebook..
Post by White Exec » Tue Feb 12, 2019 12:15 pm
Have often wondered whether a section of cut-down oversize tyre might not make a good replacement for the tinplate - assuming a decent used one can't be found.
Assich
Orga / RP numbers: 5678
Post by Assich » Wed Feb 13, 2019 9:03 pm
Other carriers are just steel rod cage round half the tyre. Easy enough to weld after bending to suit. Stainless a good option perhaps. One thing to note is that the steel frame is welded as two separate parts onto the metal sheet.
1992 build 2.0i Prestige Auto
miq
Post by miq » Fri Feb 15, 2019 8:32 am
Just remove the rusty thin metal protector, sand down the steel structure and paint it with hammerite. If you want to replace the shrout just use the bottom of a plastic barrel, an oversized tyre or make your own (like I did) using the original one as a mould and copying it in fibreglass.
Julianw
Orga / RP numbers: 4937
Post by Julianw » Fri Feb 22, 2019 11:12 am
Or perhaps one of the hard spare wheel covers from a scrapped smaller 4x4 would be a good source of non rusting material in the correct shape.
Post by White Exec » Fri Feb 22, 2019 11:19 am
That's a really good suggestion. :idea:
Assich
Post by Assich » Fri Feb 22, 2019 3:55 pm
Plus you can fix two spare wheel carriers with one cover.
