Selling off one (or bits
Post
by Dieselman » Fri Nov 10, 2017 7:32 pm
Bendito wrote:Hello everyone!
This won't be scrapped or parted out as I have bought it! It will be saved but I need your help and advice, hope you are a friendly bunch?! Who on here can help me source the parts? First XM more of an air cooled A Series man till now but really looking forward to collecting it this weekend.
Ben
As it's a non runner it will be difficult to get onto a trailer or transporter. Cut some lenghts of 2" x 1" wood to 23" long and a couple of extra square size blocks as well. Cut some 1/2" or 3/4" ply to 4" square and take it all with you.
Jack the car up with a trolley jack and feed the long lengths in from the front of each front wheel so they block between the ARB and the bottom of the strut top and add the extra packing piece on top. (keep the weight on the front wheels from here on)
Jack the rear up and pull the inner wheel-arch liner at the front edge and feed the packing pieces into the subframe tube to block the suspension arms.
Your car will then go onto a transporter, like...and have turning steering...
This car is ridin' on wood...
Julianw
- Orga / RP numbers: 4937
Post
by Julianw » Fri Nov 10, 2017 8:55 pm
Yay!
Well done for saving it, Ben.
Sent from my BV6000 using Tapatalk
Bendito
Post
by Bendito » Fri Nov 10, 2017 9:21 pm
Brilliant tip on getting it up off the floor, I was scratching my head thinking about how this might be done.
I shall go and look at the other forum and when I get it back take some pics and start a new thread.
Dean if you have parts drop me a message with costs inc P&P it would be great to get this back up and running super fast and then pick up were others have left off.
Just out of interest what sort of gadgets to Prestige's have? Perhaps more importantly what is likely to still work?!!
Post
by Dieselman » Fri Nov 10, 2017 10:10 pm
That car is advertised as everything working, including the sunroof.
The Presige got leather seats, but retained base model door cards and armrest, but that car has had leather doorcards fitted (possibly armrest too).
It has digital climate control instead of round dials and it also has cruise control.
I think the Prestige retained manual rear windows.
The rest of the spec is base "i" version.
With a Series 1 xm, I wouldn't be too bothered about spec, other than basic sack cloth seats.
Post
by Dean » Fri Nov 10, 2017 10:26 pm
No Cruise, digital info display or electric armrest or seats unfortunately unless retro-fitted over the years.
It will have the following, electric windows and mirrors, sunroof, digital climate and A/C, auto transmission, alloy wheels and ABS.
I've got some valves, camshaft, good cylinder heads X2, some ignition components, a compressor housing, turbo core with turbine and compressor wheels, plus a heap of other little bits but i should imagine all you require is the valves? need to do the autopsy first i would think before buying stuff or it could be a waste of money.
Post
by citroenxm » Sat Nov 11, 2017 7:57 am
If i remeber rightly its not a prestrge but an sei.. so its actuaally top spec in xm.. electric heated (is heaters work) seats. Wwod trim.. cruise control . Air con .. sport alloys... heated electric mirrors.. inner rear screen.. wood trim on dash and door cards.. and if still fitted.. rds radio with clarion 6 disc cd changer.. useually in the boot.. so really you have got a top spec car
Post
by xmexclusive » Sat Nov 11, 2017 10:23 am
UK "Prestige" XM's seem to cause spec questions quite regularly.
As far as I remember Prestige was not a specific model type or spec standard in the UK.
It was used a number of times during the XM production run on quite different spec models.
As a particular model neared the end of production a few extras were added and it was branded as a "Prestige".
Effectively a marketing ploy to move on old stock.
The timing was I think 1991/2, 1993/4 and 1996/7.
In each case the year before the whole range of XM's were to be revamped.
I will look out the documentation if I can find it.
The use of the various XM model/spec names also varied with the country the cars were to be sold in.
Bendito
Post
by Bendito » Sat Nov 11, 2017 10:35 am
Ah cool
Lots to learn most of the cars I play with still have a cranking handle!
I can't believe there are so few left, they still seem like ralively new cars to me. I suppose they could be nearly 30 years old now. I really fancy a nice ID or early DS but will have to wait till I sell my beetle cabriolet. Dead chuffed with this purchase I intend to use it too, I like to enjoy using my cars
Bendito
Post
by Bendito » Sat Nov 11, 2017 10:43 am
xmexclusive wrote:UK "Prestige" XM's seem to cause spec questions quite regularly.
As a kid all the posh GS and CX cars were called 'prestige' shame they devalued the name in an attempt to shift the stock.
Post
by xmexclusive » Sat Nov 11, 2017 1:05 pm
June 1991 - Special edition "Prestige" launched, new price £19245 (manual or auto), used prices 2000 similar to 2.0SEi.
May 1992 - Special 2.0i "Premiere" (£16995) and "Prestige" (£19245) launched, used prices 2000 "Premiere" = 2.0i + 5%, "Prestige" = 2.0Si + 10%.
Feb 1994 - Special editions, 2.0i turbo "Premiere" (£16300) "Onyx" (£17700) "Prestige" (£19700). "Onyx" was available as car or estate.
