Has anybody got series 2 xm/series 1 xantia steering wheel leather if possible (with buttons just in case i can get a phillips radio going or get one that works) my steering wheel is a scabby plastic coated or should say was coated
Thanks
Tim
steering wheels
Timcol
- Orga / RP numbers: RP 7183
Series 2
2.0 16v Sx
1997
Re: steering wheels
Note that there are several variants of steering wheel that look very similar, but are not directly interchangeable.
Xantia wheels are 10mm smaller in diameter (which may not be a problem for you) and the stereo controls are different.
There are 2 variants of Xantia wheel (just for the 4 spoke mk1 versions with airbag and stereo controls), depending on whether early late airbag system, so about 16 variants in all... I imagine that the XM has at least as many variants.
