Selling off one (or bits
Post
by Dieselman » Fri Jul 12, 2019 7:48 pm
xmexclusive wrote: ↑Fri Jul 12, 2019 6:11 pm
Hi Will
As I understand apart from the pipe thread size strut heads have identical geometry.
The change is effected at the bottom end.
Details are given:-
Section 7 of the workshop manual (book 058932) sheets XM 410-00/1 page 2.
This shows the plate markings on the alloy baseplate.
Difference is by plate casting angle.
Non hydractive plates are marked with a number 4 on the top of the plate.
Hydractive are marked with a number 1 on the top of the plate.
The plate holds the roll bar at the rear and the back end of the wishbone at its front.
The cast steel wishbone top clamp has a matching angle and similar marking.
Sorry no scanning facilities at present.
Got it!
I know the yolk you mean and have two that need the bolt drilling out, so will check the markings.
Note: Both ones I have where the bolt is so seized in that it snapped the head off rather than turn, are the drivers side (UK). This is because there is no protection from oil spill from the LHM tank and gearbox.
Do not try to drive the bolt out, or pry the yolk as being an alloy casting, it will snap.
Onion Johnny
- Orga / RP numbers: RP7302 Silver 01/1997 Series 2 Hatchback. 2.0 TCT
Post
by Onion Johnny » Wed Jul 17, 2019 8:38 pm
Hello Dave, What sort of money are you wanting for two decent strut tops to fit a Series II 2.0tct 1997? How do you tell if the gaiter is the larger diameter one? May need these ae well.
Ian
davetherave
Post
by davetherave » Sun Jul 28, 2019 8:49 pm
Ian- both of my decent strut tops have gone I do have strut rams/ gaitors left though.
Fredgeepm - here are some pics of calipers
Also a few pics of other bits that are left- John you mentioned locks- not sure if glove box ones are any good.
Glovebox is a mk 2 no airbag variant and the strut ram on it is full of beans.
Armrest is leather and bit next to it is motor for electric version may be useful if you want to convert to electric armrest.
(87) 2.5td Cx
(01) Gpz500s
davetherave
Post
by davetherave » Wed Jul 31, 2019 1:00 pm
More bits,also realised missed a couple of pics from above!
(87) 2.5td Cx
(01) Gpz500s
davetherave
Post
by davetherave » Wed Jul 31, 2019 1:03 pm
(87) 2.5td Cx
(01) Gpz500s
davetherave
Post
by davetherave » Wed Jul 31, 2019 1:06 pm
(87) 2.5td Cx
(01) Gpz500s
Woodie
Post
by Woodie » Thu Aug 01, 2019 2:19 pm
Have sent a PM ta
Richard
