Selling off one (or bits
davetherave
Post
by davetherave » Wed Jun 19, 2019 8:38 pm
(87) 2.5td Cx
(01) Gpz500s
demario
Post
by demario » Thu Jun 20, 2019 8:21 am
how much for rear brake covers
Post
by MTXM » Thu Jun 20, 2019 2:23 pm
Please can I have the ABS sensor Dave!! With regards, Matthew T.
ul9601
- Orga / RP numbers: don't have any
Post
by ul9601 » Fri Jun 21, 2019 3:09 am
Is the windscreen wiper stalk with adjustable intermittent setting plug-and-play for non-adjustable?
Is it NOS and how much would that be?
Cheers
'91 carb'd 2.0 manual
Lwdajo
Post
by Lwdajo » Fri Jun 21, 2019 5:07 pm
I've just been informed I also need a replacement front ABS sensor! My ABS isn't working, car is juddering and they've got it down to one front sensor not transmitting a signal. The reluctor rings have been changed.
I don't suppose you have two sensors David?
Regards,
Lee
davetherave
Post
by davetherave » Sat Jun 22, 2019 7:02 am
Sorry for lack of replies on here! Have been responding to pms and will update what is available soon. Disc shields are spoken for I'm afraid.
Matthew has claimed abs sensor
NOS Wiper stalk also claimed but i am sure i have other used ones.
I am sure i may have other sbs sensors and will confirm on next garage sort!
(87) 2.5td Cx
(01) Gpz500s
Southerneruk
Post
by Southerneruk » Thu Jun 27, 2019 11:57 pm
how much for the diesel pump, mine leaks abit though the presure regulator
Post
by Dean » Fri Jun 28, 2019 10:46 pm
ul9601 wrote: ↑Fri Jun 21, 2019 3:09 am
Cheers
Sort of, fitting it will give you the variable intermittent wipers function but you will have to re-pin one of the wires on the harness plug, can't remember which (I think it could be the washer function) but if you look at the new stalk and the loom plug you will see one terminal on the int wipe stalk is moved to a different location when compared to a standard non int wipe stalk, it will be pretty straight forward when you see it.
davetherave
Post
by davetherave » Fri Jul 05, 2019 8:48 am
If anyone going to little horwood this weekend I will be there tomorrow so can bring some bits.
(87) 2.5td Cx
(01) Gpz500s
Assich
- Orga / RP numbers: 5678
Post
by Assich » Sun Jul 07, 2019 6:47 pm
That's interesting Dean. I just fitted a variable stalk in place of a standard one in my 92 build and works as should without rewiring.
1992 build 2.0i Prestige Auto
