Wanted, Drivers Door Airflow Vent Rubber Trim
The rubber trim that sits around the airflow vent on the inside of the drivers door frame finally fell off. Does anyone know of a supply of these?
TIA Paul
TIA Paul
Citroen XM (MK1.5) Prestige, 2.0i Turbo. Black
Re: Wanted, Drivers Door Airflow Vent Rubber Trim
On the dash or the door card itself?
- Orga / RP numbers: PRV V6 auto LHD 6751
I guess he means on the forward face of the B pillar. Mine is half off. I've been watching to see if anyone has any bright ideas.
Derek
1995 XM V6 LHD Diravi Blue
2007 C5 Exclusive Estate
Carefully lever the duct out of the B pillar trim, then refit the seal, adding a smear of adhesive, if necessary, then push the guide back in until it clips in.
The guide clips are at the sides.
I have removed a number of B pillar trims so should have some good ones about as I just took them out complete without any dismantling..
I have mrk1 rubbers
I too need a new sealing rubber for the drivers side. Mine was damaged by a rather large journalist at the SMMT press day yesterday.
Lol. OK Rob. I'll sort you one out.. Get it sent down..
Me too, I lost mine it must have fallen off finally. I have two I could trade, I have some from eBay I purchased but they don’t fit well (too big). My guess is they’re different between Y1 Y2. I’m after a Y1 set if anyone has these for sale or a trade.
