Got one of these, brand new. Bought it for my 2.5 years ago and never used it.
Any interest?
£30 posted to you.
e crofting repair kit for hydraulics
endorfin
Lwdajo
Re: e crofting repair kit for hydraulics
I've just been reading about this - someone described having a hard suspension at slow speeds, over small bumps, and this fixed the problem. It works by replacing the diodes I believe?
I have this problem with my suspension after a sphere change, so I'll take it off your hands.
Does the unit fit all models and years? Are wiring details provided?
Cheers,
Lee
Cheers,
Lee
endorfin
Yes that's how it works, works for all models.
Unfortunately I don't have the A4 page that had the instructions but you can email Roy Mackay for a copy, he's very obliging. His email is:
roy.mackay@e-crofting.com
Someone else here may have a copy.
Inbox me with your address details.
Unit, I think, just contains two diodes, and three connections:
- Ground
- Connection for front EV +supply
- Connection for rear EV +supply
If used on an early car with Hydractive I (single EV), then only one of the last two needs be used.
- Ground
Lwdajo
Cheers for the info guys.
I've pm'ed you.
I've pm'ed you.
