Wanted. XM V6 water pump
- Orga / RP numbers: 6401
Re: Wanted. XM V6 water pump
Dont know for sure if the 12V PRV uses the same pump, looks the same.
I have 2 spares, breaking a 12v which has been beyond repair..
XM V6.24 Manual
XM V6.12 Autobox
XM V6 ES9J4 Manual
205 GTI RFS
205 GTI Mi16
XM V6.12 Autobox
XM V6 ES9J4 Manual
205 GTI RFS
205 GTI Mi16
Yes water pumps are the same on 12v and 24v engines (Prv) ..
water pump update!
So after several weeks I have my unrepaired water pump back from the eBay "classic car water pump reconditioning specialists".
They said the they had 4 tonnes of pressure on the pulley and heated it up and could not get it off.
I stuck it on the press at work at I think the gauge didn't even hit 2 tonnes before the pulley started moving....
The black paint on the pulley out of a rattle can survived the heat they allegedly applied too.
So following a suggestion of someone on here I popped over to SP waterpumps today and dropped the pump off, it'll be ready tomorrow. Wish I'd tried them weeks ago.
1991 XM 24V S1
1991 Renault 25 2.9i Baccara
1994 Renault Safrane 3.0i RXE
1984 Talbot Tagora SX 2.6
1980 Renault 30TX auto phase 1
1980 Renault 30TX manual phase 1
1982 Renault 5 Gordini Turbo
That one i give you no good darren?
Hi Paul, I did try it but it leaked worse than mine. I didn't buy it to use it though I bought it to use the pulley off it as I was told my pulley wouldn't come off. I may get it rebuilt by SP and keep it on one side as a spare.
1991 XM 24V S1
I was pleased to hear that SP was able to assist you Darren and they also served me well. My only criticism was in relation to repainting the pump black, when it should be silver, but that was soon sorted! Regards, Matthew T.
Wow.. and it felt quite tight too.. just goes to show!
My pump came out of SP looking like new. They'd blasted the alloy and the impeller and left them like that and then painted the pulley black which strictly speaking isn't factory as the pulley should be zinc plated but as you can't see it when fitted I'm not too bothered about. SP also fitted an updated more modern seal so should last a few good years now. I dropped the pull off at 3 in the afternoon yesterday and got a call at half nine this morning to say it was done! Great service.
1991 XM 24V S1
