3.0 V6-24 Project
Re: 3.0 V6-24 Project
Post by Dieselman » Tue Jul 11, 2017 6:35 pm
I'll leave you two to it...
Post by Dieselman » Wed Jul 12, 2017 10:09 pm
Worked on the car again this evening...a bit too late actually...Oops.
The coil and ignition amplifier are good and so is the ECU. The keypad, I believe, is now fixed.
And...I found the coolant header tank is split and the engine runs at around 100c and has a bit of a misfire.
Post by Dean » Wed Jul 12, 2017 10:47 pm
success then, sort of.
was it the ECU box wiring causing the issue?
Post by MTXM » Thu Jul 13, 2017 9:05 am
That is fantastic news that the car now runs Will and the split coolant tank is an easy fix, while the 24v does tend to run quite hot! We eagerly await further updates, including on the behaviour of the hydraulics! Regards, Matthew T.
Post by citroenxm » Thu Jul 13, 2017 9:20 am
Id get the thermo stat changed for a lower rated one.. i feel better running at 80 rather then 100.. its in a great place too.. under the left side too engine mount bar that holds the aux belt tensioner too... well done getting some life i really hope the misfire is a plug or lead only and nothing internal!!
Post by russ92xmsed » Thu Jul 13, 2017 12:22 pm
Brilliant news on getting it going. Well done. :)
Post by Dieselman » Sat Jul 15, 2017 12:56 pm
First start in many years.
https://www.youtube.com/watch?v=loWAkU4KnDg" onclick="window.open(this.href);return false;
sdelasal
Post by sdelasal » Sat Jul 15, 2017 2:27 pm
Well done. p.s. what's the temperature gauge for, underneath the tachometer?
Post by citroenxm » Sat Jul 15, 2017 3:19 pm
Thats oil temp sensor steve.. fitted only to 24v engines in s1
Post by Dean » Sat Jul 15, 2017 4:55 pm
Little bit of first start smoke, that will clear.
Sounds smooth though, pleased to see the engine is fine I take it!
