XM electronic dash mounted heater control unit.
hank123
WANTED Fully working dash mounted electronic heater control unit for 1994 Y4 XM none A/C. Thank you
Re: XM electronic dash mounted heater control unit.
Roatry dial type unit??
hank123
hank123
Hi, thanks for your reply. I'm unable to view pic for some reason? Regards
- misha
The picture will reveal after clicking on the window.
- djg
- Orga / RP numbers: 7903
Saved from PB...
Bye,
Gábor
Gábor
Reminder, not to use Photobucket for linking photos to forums. Previous free use of this is now routinely blocked. Upload pics directly by using the Upload Attachment tab below.
