Forum running very slow
Post by Dieselman » Tue Sep 13, 2016 3:20 pm
As the title, the forum is running very slowly and stalling. I note sam Skelton has noticed the same.
Re: Forum running very slow
Post by xmexclusive » Tue Sep 13, 2016 3:35 pm
Hi Will
I took this up with Ciaran a few days ago when I had trouble loading images.
He is hoping to do a server rebuild as soon as he finds time.
Post by citroenxm » Tue Sep 13, 2016 7:11 pm
It is a forum issue. I have the same problem..
Post by White Exec » Tue Sep 13, 2016 7:37 pm
Me too. I'm sure it will be sorted out - thanks in anticipation.
I did find it exceptionally slow just to get the up-front Login page, and switched my toolbar login icon simply to
"www.club-xm.co.uk/forum/ucp.php?mode=login"
which is working a good bit quicker.
Post by russ92xmsed » Wed Sep 14, 2016 12:28 pm
Good, thought it was me Internet. Noticed the forum has been very intermittent recently.
Post by xantia_v6 » Wed Sep 14, 2016 7:11 pm
We don't seem to have this periodic slowdown on FCF, but we run a Linux stack under phpBB rather than Microsoft.
Mike (FCF admin team member)
Jan-hendrik
Post by Jan-hendrik » Wed Sep 14, 2016 10:39 pm
September 14 I wasn't able to connect at all :shock:
Post by russ92xmsed » Sat Sep 17, 2016 4:47 pm
Forum is running very oddly this evening.
Ciaran
Site Admin
Orga / RP numbers: 1234
5678
91011
Post by Ciaran » Fri Sep 23, 2016 6:51 pm
Hi guys,
Sorry for the intermittent slowness for the past few weeks, took a while to track down as the webserver itself was running quite nicely, it turns out the root cause was a faulty router, which was intermittently dropping packets and other weird behaviour. It would be fine for a time, performance would dip, by the time I looked at it, it would be running like lightening again, rinse and repeat.
What gave it away in the end was the alarming brown heat marks on the outside casing! :o
Ciarán
Post by White Exec » Fri Sep 23, 2016 7:16 pm
Bit like our old friend F2 . . . :roll:
Thanks, Ciaran, for all the hard work in seeing this through.
