I need a replacement of item 12 as mine is missing. A 55.5mm diameter o-ring.
Can anyone either photograph and measure the thickness of one they have to hand so I can see if I can order a generic replacement?
Even better: could someone spare an original?
viewtopic.php?f=5&t=7814#p92556
Thanks!
Wanted: 2.1 intake pipe o-ring
- jamescarruthers
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
Re: Wanted: 2.1 intake pipe o-ring
I think the 55,5 designation means diameter 55mm, profile 5mm
- jamescarruthers
Ah okay, that's handy, thanks. It is the profile that I'm unsure about.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
Yours is the setup where those two pipes are clipped together..
Later cars were modified and they were connected with a intermediate hose and two hose clip bands... Prehaps worth upgrading to that setup.. ? Thats if you cant get the O ring seal. Ive most likely got the three pipes here. You need to swap the one to the top of the turbo.. And the front one to the intercooler and the joining pipe..
- jamescarruthers
Ordered one, 55mm x 5mm, made of Viton material. Nitrile would have been fine too I guess.
Thanks again!
Thanks again!
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
- jamescarruthers
Thanks Paul, got the o-ring on order now. I will bear the upgrade in mind if I have difficulty getting it to seal with the original setup.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
