P820 UNM
Think you've spied another forum member's XM out on the roads? Ask in here!
kingp
P820 UNM
Post by kingp »
Blue auto turbo hatchback spotted near Manchester airport, anybodies on here?!
Degens
Re: P820 UNM
Post by Degens »
That was me ;-). I use it to commute to work.
Today and tomorrow (17 and 19 Sept 2016) it is at the classic car show in Manchester
Unfortunately, it has oil in the coolant and it is thousands of pounds to get it repaired. If anyone is happy to repair it for me (leaking head gasket and failing turbo) I am happy to pay £800; unfortunately I know nothing about mechanics...
Hans
raynoon
Orga / RP numbers: 6043
Re: P820 UNM
Post by raynoon »
I saw that at the show yesterday, a lovely colour blue.
Re: P820 UNM
Ive got a tct block attached to an autobox here.. but I do think ive got rid of the turbo units..
is it a turbo issue or a oil cooler issue..? I know it can be either as water passes through the turbo as well as oil..
Degens
Re: P820 UNM
Post by Degens »
The garage checked the oil cooler and told me that that was fine; It is, as far as I understood the Turbo and/or Headgasket which they advised to get repaired both. The thing you have, would that solve the issue of my car?
Thanks for replying; much appreciated!!!!
Re: P820 UNM
Post by White Exec »
No problem: we're happy to help.
It will help us if you can post everything related to the issue in one thread - your other one!
Thanks.
kingp
Re: P820 UNM
Post by kingp »
Hans, if your nearby to Manchester drop me a PM as I can reccomend a local specialist but £800 may stretch the budget for a headgasket replacement which is more than likely the issue to be fair as when the turbos go they very very rarely leak water and oil and mix it .
Julianw
Orga / RP numbers: 4937
Re: P820 UNM
Post by Julianw »
Spotted recently in Congleton so I guess the HG issue has been resolved. Looking good, too!
Degens
Re: P820 UNM
Post by Degens »
Yes, indeed, someone on the forum was so kind to repair it!!! It is still going strong with all the gadgets working (except occasionally the cruise control not working and then later it works again!). I am so pleased he repaired it and I can still use it!
Julianw
Re: P820 UNM
Post by Julianw »
This place! :D
And
Cruise! I dream of cruise...
