Window regulator needed.
m0rda
Orga / RP numbers: 7133
1996 3.0 V6 VSX, hatchback, auto, Diravi
Re: Window regulator needed.
Post by m0rda » Wed Aug 31, 2022 12:42 pm
Yes, I understand it is - all the circuitry for the rear windows is missing. Only things I had, were the console buttons, which were just hanging in the air. Judging by that, I thought that rear windows were electric, but they were actually not. My mistake :(
At the moment, I have all the buttons, relays and rear-left winder.
The most interesting will be to find points "9/B4", "9/B1" and "13/A2", to which the relay 810 and backlight connect to.
m0rda
1996 XM 3.0 V6 VSX Auto RP7133
Post by citroenxm » Wed Aug 31, 2022 2:05 pm
I should have a spare harness somewhere i stripped a v6 sei and a 2.1 sed both with rear power windows.
Finding the harness or at least identifying it is another thing.
m0rda
Post by m0rda » Wed Aug 31, 2022 3:02 pm
The only hint I might have is that there should be these 5-pin connectors:
These are connectors to door buttons.
m0rda
Post by citroenxm » Wed Aug 31, 2022 3:51 pm
Yea they are the door ones.. the centre console ones are the same as the dash switches ...
Post by Dieselman » Thu Sep 01, 2022 7:07 am
Are S1 and S2 harnesses the same?
Post by Dieselman » Thu Sep 01, 2022 7:09 am
I've not checked, but iirc, the relay plugs into the main fues/relay board and the connections are from that board and behind the radio, as said by citroenxm.
Series 2 circuit diagrams.
https://www.club-xm.co.uk/forum/downloa ... hp?id=9711
m0rda
Post by m0rda » Thu Sep 01, 2022 7:15 am
Buttons are the same, for sure. The difference might be in motor connectors, as S2 and S1 motors are different.
However, I haven't had a chance to compare, as was an owner of S1 or S2, but not both at the same time.
I would say, for my purpose, S1 harnesses would do, as I only don't have console button connectors.
m0rda
