Citroen XM NOS parts for sale
Mish_Mish
Orga / RP numbers: 5111
Re: Citroen XM NOS parts for sale
Post by Mish_Mish » Fri Jan 18, 2019 7:36 pm
I just bought that radiator from you on eBay, could use few other things if you have used / new parts available.
Thanks
CitroRS
Post by CitroRS » Sun Apr 07, 2019 6:15 am
Hello everybody. I'll be coming to Citromobile in May, so I can bring some parts with me if anyone is interested.
I also found 2 NOS front wings for XM, part numbers 96008528 and 96008529, as well as used bumpers in very good state. Delivery to Citromobile is free of charge, of course.
Post by Dieselman » Sun Apr 07, 2019 7:34 am
Can you please give an updated list.
Also see what you can find in other local stock.
CitroRS
Post by CitroRS » Sun Apr 07, 2019 9:08 am
Will do that soon, I have most of the lists but just have to translate them.
I also found large stock of used XM parts, stock is too big to sort it out until Citromobile but will post some photos I made.
CitroRS
Post by CitroRS » Wed Apr 24, 2019 10:17 pm
Here is the updated list:
2. Front left strut top/suspension sphere bracket without Hydractive - 5271.79 (just have to check the number again) - 1
3. Clutch plate 2.0 petrol without a box - 1
4. Clutch set Valeo TD without a box, some moisture damage - 6541.K1
7. GRAF front brake discs 2.0, 2.1, 3.0 283 mm - 96099616 - 1
8. Handbrake cable - 96012379 - 2
9. Accelerator cable - 32903 - 2
13. Window trim OEM - 96020614 - 1
16. Front right indicator without fog lamp Valeo, without a box, one damaged - 082757 - 2
17. Rear door trim OEM - 95640881YB - 1
21. Front grille part S1 - 9600261577 - 1
24. Front hose OEM - 6457.Y1 - 1
26. Water hose 2.0 - 96086789 - 1
27. Water hose 2.0 - 1343.C6 - 1
28. Plastic part - 96077405 - 1
29. Water hose OEM - 96057424 - 1
30. Water hose 2.0 - 96086789 - 1
31. Fuel filler cap OEM - 9608890900 - 1
33. Hydraulic reservoir compensator OEM - 96014072 - 1
35. GRAF water pump 2.1 diesel - PA542/1201.55/96047088 - 1
36. Brake caliper metal part Bendix//caliper joke front brakes - 95653170 - 1
37. Idle compensator OEM - 0345.56 - 1
38. Vernet temperature switch - 1627 - 7
39. Cylinder block core plug OEM - 0163.28 - 1
40. Boot light switch OEM - 95656499 - 1
41. Rheostat screw OEM - 1531.09 - 1
42. Air dosage housing bracket OEM 3.0 - 0363.26 - 1
43. SNT tensioner - 374356 - 2
44. Thermostat seal OEM - 1340.14 - 1
45. Stop switch FAE - 4057 - 1
46. Temperature switch diesel OEM - 95638684 - 1
47. Sachs release bearing diesel - 3151874001 - 1
48. Sensor/modulation motor (?) OEM - 6445.T3 - 1
50. Water hose without A/C OEM - 96043314 - 1
51. Tank filler cap - XS819 - 1
52. Timing belt tensioner diesel OEM - 0830.14 - 1
53. Timing belt tensioner diesel OEM - 0818.19 - 1
54. Engine bearing Vanderwell -0,30 mm - VDR92569A - 1
55. Osvat exhaust valve set 2.0 - 0989 BMC - 3
56. Hydraulic pump pulley diesel OEM - 96117523 - 1
57. Front left strut top/suspension sphere bracket with Hydractive used - 96149390 - 1
58. Air filter OEM - 9401444108 - 1
59. Hydraulic pump belt Rofan - 1A1025 - 2
60. Lower gasket set 2.0 Payen - 013537 - 1
61. Gasket set diesel without head gasket Ajusa - CT-7100-H - 1
62. Head gasket 2.1 diesel Glaser - 12354 70F - 1
63. Intake manifold seal 2.5 TD OEM - 0348.F9 - 1
64. Diesel gasket set OEM - 0197.H1 - 1
65. Gasket set 2.0 OEM - 0197.C8 - 1
68. Temperature sensor OEM - 96018426 - 1
69. Water temperature casing OEM - 0242.73 - 2
71. Thermostat 2.0 without a box - 4638.89 - 2
74. Hydraulic tube fixing bracket OEM - 5280.J4 - 1
76. FRAD fuel filter diesel - 20.059K-43-59-02 - 4
77. Thermostat seal diesel OEM - 1339.66 - 4
81. Temperature switch Vernet - 1627 - 4
82. Injector 3.0 OEM - 1984.82 - 4
83. Temperature switch FAE 3.0 - 37940 - 2
84. Hydraulic tube fixing bracket OEM - 5280.J3 - 1
88. Works connection injection+ZPJ+Diravi OEM - 96142040 - 1
89. Water temperature sensor OEM - 96092918 - 4
90. Upper radiator holder OEM - 96009729 - 2
91. FRAD fuel filter diesel - 43.59.02/30 - 2
92. Stationary window joint OEM - 96025938 - 1
93. Temperature sensor/heater core OEM - 95651014 - 2
94. Rear wiper motor+mechanism Bosch OEM - 95652999 - 1
95. Speed sensor OEM - 96008163 - 1
96. Steering rack shaft screw OEM - 4043.30 - 1
97. Water temperature sensor without A/C OEM - 96008159 - 3
99. Bracket for some sensor for A/C OEM - 6445.59 - 1
100. Clutch release bearing without a box - 96090882 - 2
101. Brake caliper metal part/caliper joke front brakes OEM - 4404.20 - 1
102. Caliper joke front brakes+sliders Bendix OEM - 95653169 - 1
104. Intake valve Osvat 2.0 set - 780988 - 3
105. Engine bearing 2.0 repar OEM - 0606.J5 - 2
108. Water hose - 96403800 - 1
109. Brake set column screw set OEM - 4448.68 - 1
110. Anti roll bar stabilizer link Sasic - 0875415 - 1
111. Stabilizer OEM - 5087.49 - 3
112. Front triangle arm wishbone bush OEM - 3523.44 - 2
113. Kolbenschmidt piston set 2.1 TD with piston rings, moisture damage - 90686610 - 1
114. Driveshaft bellow Sasic 3.0 100x30 opened bag - 2933983 - 2
115. Driveshaft bellow gearbox side 75x33 Sasic opened bag - 2873813 - 1
116. Driveshaft bellow Meillor opened bag - 329726H - 1
121. Ignition cables GREGOIRE BARILLEAU without a box - 636599 - 1
123. Crankcase for A/C models excl. V6 - 96014066 - 1
124. Front right suspension strut return tube 2.0 without a box - 96076633 - 1
126. Head gasket Payen 2.1 TD 1,64 mm - 047053 - 2
127. Head gasket Payen 2.1 TD 1,54 mm - 047052 - 1
128. Head gasket XUD11A Ajusa 1,7 mm - CT7105ADKS - 1
129. Head gasket Glaser 2.0 - 07967-80 - 1
130. Gasket set 2.0 Glaser with head gasket - S31115-80F - 1
133. Throttle valve contact switch 2.0 OEM - 1628.K9 - 1
134. Throttle position potentiometer 2.0 OEM - 1628.R0 - 1
136. Intake valve 3.0 V6 OEM - 7910248148 - 6
137. Exhaust valve 3.0 V6 OEM - 0949.61 - 6
138. NOS front wiring harness for Series 1 - 96064009 80. It should fit XM 2.0i Ambiance/Harmonie and 3.0 V6/ 3.0 24V until ORGA 04922, according to service.citroen.
I will try to translate the othe lists soon, and post photos of used parts stock I found.
If anyone is interested in parts, it would be good to close orders until April 30, since I'm heading to Citromobile on May 1st.
Jujmau
XM newbie
Orga / RP numbers: Citroën xm v6 24 1991 ORGA 5316
Post by Jujmau » Mon Oct 30, 2023 10:58 pm
Hello, is the part number 88 still available ? If so, is it fesable to send it to France ? What is it's price? What is your name on eBay ?
Degens
Post by Degens » Fri Nov 03, 2023 8:57 pm
I don't know how the part is called, but do you have the part indicated in the picture related to the hinge of the door on the right side front. It is the metal part on the frame of the door I am after.
Post by Dieselman » Sat Nov 04, 2023 8:57 am
You need the door lock striker. 9164 40
All Xm use the same type of striker, late S2 cars are coloured black, not silver. Any scrap Xm will yield some, if not a full set.
Post by citroenxm » Sat Nov 04, 2023 10:32 am
Early cars used a roll pin between the A pillar part and the arm of the check strap.. later it was changed to a rivet type fixing and wasn't.. or didn't appear to be seperatable
Incidentally front door check straps carry a different part number to rear ones. But they are not sided .
Degens
Post by Degens » Sat Nov 04, 2023 11:23 am
Thanks Dieselman and Citroenxm. Does one of you perhaps have it? Happy to pay for it.
