Citroen XM NOS parts for sale
CitroRS
Post by CitroRS » Mon Feb 01, 2016 11:50 pm
Hi guys! As I promised, here is the list of NOS XM parts I have, and I marked genuine Citroen parts with OEM. I entered a part number where possible, and then quantity availiable.
One thing about cables - most of them are not OEM but Cofle or Telco. So let's start:
1. Bumper bracket new - 95640667 (new number 7414.C6) - 1
2. Front left strut top/suspension sphere bracket without Hydractive - 5271.79 (just have to check the number again) - 1
3. Clutch plate 2.0 petrol without a box - 1
4. Clutch set Valeo TD without a box, some moisture damage - 6541.K1
5. Air condition condenser without a box (new, but some dents on aluminium plates due to out of box storage) - 96134218 - 1
6. GRAF front brake discs 2.0, 2.1, 3.0 275 mm - 96054779 - 1
7. GRAF front brake discs 2.0, 2.1, 3.0 283 mm - 96099616 - 1
8. Handbrake cable - 96012379 - 2
9. Accelerator cable - 32903 - 2
10. Diravi cable regulator flexible OEM - 96023356 - 1
11. Handbrake cable - 96012416 - 1
12. Handbrake release cable OEM - 96102237 - 1
13. Window trim OEM - 96020614 - 1
14. Complete left driveshaft with ABS, some moisture damage, without a box - 3272.90 - 1
15. Complete right driveshaft with ABS, some moisture damage, without a box - 3273.H8 (or HB instead H8, couldn't read clearly) - 1
16. Front right indicator without fog lamp Valeo, without a box, one damaged - 082757 - 2
17. Rear door trim OEM - 95640881YB - 1
18. Handbrake cable ZPJ4 right - 96026873/92104682 - 3
19. Left exterior complete rear view mirror with tinted glass and mirror heater OEM - no number on the box - 1
20. Body displacement sensor OEM - 96122910 - 1
21. Front grille part S1 - 9600261577 - 1
22. Automatic gearbox oil gauge OEM - 2266.31 - 1
23. Windscreen wiper switch OEM - 95637980XX - 1
24. Front hose OEM - 6457.Y1 - 1
25. XM dash display, without a box, with some tape over the screen - 339267 01 - 1
26. Water hose 2.0 - 96086789 - 1
27. Water hose 2.0 - 1343.C6 - 1
28. Plastic part - 96077405 - 1
29. Water hose OEM - 96057424 - 1
30. Water hose 2.0 - 96086789 - 1
31. Fuel filler cap OEM - 9608890900 - 1
32. Air intake pipe to relay box - 96039554 - 1
33. Hydraulic reservoir compensator OEM - 96014072 - 1
34. ABS sensor OEM - 96161385 - 1
35. GRAF water pump 2.1 diesel - PA542/1201.55/96047088 - 1
36. Brake caliper metal part Bendix//caliper joke front brakes - 95653170 - 1
37. Idle compensator OEM - 0345.56 - 1
38. Vernet temperature switch - 1627 - 7
39. Cylinder block core plug OEM - 0163.28 - 1
40. Boot light switch OEM - 95656499 - 1
41. Rheostat screw OEM - 1531.09 - 1
42. Air dosage housing bracket OEM 3.0 - 0363.26 - 1
43. SNT tensioner - 374356 - 2
44. Thermostat seal OEM - 1340.14 - 1
45. Stop switch FAE - 4057 - 1
46. Temperature switch diesel OEM - 95638684 - 1
47. Sachs release bearing diesel - 3151874001 - 1
48. Sensor/modulation motor (?) OEM - 6445.T3 - 1
49. Water hose diesel OEM - 96054374 - 2
50. Water hose without A/C OEM - 96043314 - 1
51. Tank filler cap - XS819 - 1
52. Timing belt tensioner diesel OEM - 0830.14 - 1
53. Timing belt tensioner diesel OEM - 0818.19 - 1
54. Engine bearing Vanderwell -0,30 mm - VDR92569A - 1
55. Osvat exhaust valve set 2.0 - 0989 BMC - 3
56. Hydraulic pump pulley diesel OEM - 96117523 - 1
57. Front left strut top/suspension sphere bracket with Hydractive used - 96149390 - 1
58. Air filter OEM - 9401444108 - 1
59. Hydraulic pump belt Rofan - 1A1025 - 2
60. Lower gasket set 2.0 Payen - 013537 - 1
61. Gasket set diesel without head gasket Ajusa - CT-7100-H - 1
62. Head gasket 2.1 diesel Glaser - 12354 70F - 1
63. Intake manifold seal 2.5 TD OEM - 0348.F9 - 1
64. Diesel gasket set OEM - 0197.H1 - 1
65. Gasket set 2.0 OEM - 0197.C8 - 1
66. Lighting switch OEM - 6253.55 - 1
67. Cooling fan temperature switch OEM - 95638684 - 1
68. Temperature sensor OEM - 96018426 - 1
69. Water temperature casing OEM - 0242.73 - 2
70. Cooling fan temperature switch 2.0, 2.1 OEM - 96064561 - 1
71. Thermostat 2.0 without a box - 4638.89 - 2
72. Fuel pressure regulator 3.0 OEM - 1563.A5 - 1
73. Water temperature sensor OEM - 1338.09 - 1
74. Hydraulic tube fixing bracket OEM - 5280.J4 - 1
76. FRAD fuel filter diesel - 20.059K-43-59-02 - 4
77. Thermostat seal diesel OEM - 1339.66 - 4
78. Interior door lock button OEM - 96002473ZL - 3
79. Door hinge shaft OEM - 96085422 - 4
80. Gearbox lever OEM - 96068122 - 1
81. Temperature switch Vernet - 1627 - 4
82. Injector 3.0 OEM - 1984.82 - 4
83. Temperature switch FAE 3.0 - 37940 - 2
84. Hydraulic tube fixing bracket OEM - 5280.J3 - 1
85. Cooling fan temperature switch Vernet - 1769 - 2
87. Door window guide OEM - 95291417 - 6
88. Works connection injection+ZPJ+Diravi OEM - 96142040 - 1
89. Water temperature sensor OEM - 96092918 - 4
90. Upper radiator holder OEM - 96009729 - 2
91. FRAD fuel filter diesel - 43.59.02/30 - 2
92. Stationary window joint OEM - 96025938 - 1
93. Temperature sensor/heater core OEM - 95651014 - 2
94. Rear wiper motor+mechanism Bosch OEM - 95652999 - 1
95. Speed sensor OEM - 96008163 - 1
96. Steering rack shaft screw OEM - 4043.30 - 1
97. Water temperature sensor without A/C OEM - 96008159 - 3
98. A/C switch OEM - 96023272ZL - 1
99. Bracket for some sensor for A/C OEM - 6445.59 - 1
100. Clutch release bearing without a box - 96090882 - 2
101. Brake caliper metal part/caliper joke front brakes OEM - 4404.20 - 1
102. Caliper joke front brakes+sliders Bendix OEM - 95653169 - 1
103. Exhaust manifold 3.0 damaged by moisture - 0341.72 - 1
104. Intake valve Osvat 2.0 set - 780988 - 3
105. Engine bearing 2.0 repar OEM - 0606.J5 - 2
106. Heater control knob OEM - 95655230ZL - 1
107. Front wheels mud flaps pair - ZC9867879U - 1
108. Water hose - 96403800 - 1
109. Brake set column screw set OEM - 4448.68 - 1
110. Anti roll bar stabilizer link Sasic - 0875415 - 1
111. Stabilizer OEM - 5087.49 - 3
112. Front triangle arm wishbone bush OEM - 3523.44 - 2
113. Kolbenschmidt piston set 2.1 TD with piston rings, moisture damage - 90686610 - 1
114. Driveshaft bellow Sasic 3.0 100x30 opened bag - 2933983 - 2
115. Driveshaft bellow gearbox side 75x33 Sasic opened bag - 2873813 - 1
116. Driveshaft bellow Meillor opened bag - 329726H - 1
117. Bendix brake pads set - 571369B - 1
118. Front brake pads set LPR - IP05P328 - 1
119. Front right window lifter with sensor OEM - 9222.98 - 1
120. Front right window lifter without a sensor OEM - 9222.E2 - 1
121. Ignition cables GREGOIRE BARILLEAU without a box - 636599 - 1
122. Computer housing without a box OEM - 96089112 - 1
123. Crankcase for A/C models excl. V6 - 96014066 - 1
124. Front right suspension strut return tube 2.0 without a box - 96076633 - 1
126. Head gasket Payen 2.1 TD 1,64 mm - 047053 - 2
127. Head gasket Payen 2.1 TD 1,54 mm - 047052 - 1
128. Head gasket XUD11A Ajusa 1,7 mm - CT7105ADKS - 1
129. Head gasket Glaser 2.0 - 07967-80 - 1
130. Gasket set 2.0 Glaser with head gasket - S31115-80F - 1
131. Steering rack for models with Hydractive new, without a box, one tie rod end missing - 4000.T3
132. Headlight glass - have to check which side, I know I saw 2, could be for S2 - turned out to be for Peugeot 605
133. Throttle valve contact switch 2.0 OEM - 1628.K9 - 1
134. Throttle position potentiometer 2.0 OEM - 1628.R0 - 1
UPDATE:
135. Chain tensioner 3.0 V6 OEM - 0829.08 - 3
136. Intake valve 3.0 V6 OEM - 7910248148 - 6
137. Exhaust valve 3.0 V6 OEM - 0949.61 - 6
138. Timing chain guide 3.0 V6 OEM - 0829.05 - 1
UPDATE 2:
139. Valve for early Hydractive models, without a box, looks like part number is 95637614, check the pictures here - link, link and link.
There are also a lot of parts for CX, AX, ZX, Xantia, Peugeot 605, 405 etc, so ask if you are interested in these parts - I could make lists of these too!
I'm here for any question you may have. :)
raynoon
Orga / RP numbers: 6043
Re: Citroen XM NOS parts for sale
Post by raynoon » Tue Feb 02, 2016 6:10 am
Hi, can you give me a price for these please? And pics too? If pics are too much hassle can I just see a pic of number 75
70
49
67
73
75
85
Roughly how much is postage to the UK?
CitroRS
Post by CitroRS » Tue Feb 02, 2016 8:13 am
I've sent you a PM. : )
jamescarruthers
Post by jamescarruthers » Tue Feb 02, 2016 9:55 am
Hi, I know you were hoping to sell as a lot, but if you would be willing to split then I would be very interested in:
78. Interior door lock button OEM - 96002473ZL - 5
Thanks,
James
P.S. You don't have any XM radios do you?
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
CitroRS
Post by CitroRS » Tue Feb 02, 2016 10:00 am
There is no problem with splitting the parts, I know how hard it is to buy entire lot - had to pass few BX lots due to financial moment. :(
I'll be going to the storage today or tomorrow, I'll pick up these parts and PM you the pictures so you can see if they suit you. :)
edit: forgot to say, there are no XM radios, but I can check local adds for used ones if you need any specific (I think Clarion was originaly placed in XM with steering wheel commands).
jamescarruthers
Post by jamescarruthers » Tue Feb 02, 2016 12:14 pm
Yes, I am after one of the Clarions to work with my 4 button steering wheel. They come in Black or Grey, the Black being a little more modern and powerful.
Pleased you are offering the parts on here.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
CitroRS
Post by CitroRS » Tue Feb 02, 2016 2:44 pm
I know few guys that were breaking XM's here while they were common on the roads, I will check for radio and give you the price. Were these radios for MC or CD? Could you also please just send me exact Clarion model, and are you interested only in black one or grey is also an option?
Post by Dieselman » Tue Feb 02, 2016 3:22 pm
Iirc. The model is Clarion 3100 for the grey one with cassette.
The black one is Phillips.
jamescarruthers
Post by jamescarruthers » Tue Feb 02, 2016 4:32 pm
Philips might be for the S2 and not for the S1, four button wheel.
For the S1 they are both Clarion. I have a broken one of each in the boot (knackered output on 2x channels; corrupt Code PROM.)
I will photograph both and post on here for you Citro RS. Obviously I am only interested in ones with 4 working channels!
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
CitroRS
Post by CitroRS » Tue Feb 02, 2016 4:42 pm
I've just sent a message to a guy that might have it (he has a room full of radios, if he doesn't have it I just don't know ho has), but as much as I know him price is not going to be so low. :\
