Here is a shot after further painting! Regards, Matthew T.That's quite a difference on the gold car Matthew.
K725 KVG (former home)
Re: K725 KVG has a new home
Perfection!
Thanks Russ!! With regards, Matthew T>
Yes, absolutely. The shuts and lines are probably better than when it left the factory!russ92xmsed wrote:Perfection!
Quite a head-turner. Brilliant job
I think TBH the only new paint was on the front offside wing and rear nearside door Chris, with more recent welding on the sills! Regards, Matthew T.
Unlikely. The body was built by robots with incredibly accurate alignment. Panel fit wasn't an issue on any new Citroen since the 1970's.White Exec wrote:Yes, absolutely. The shuts and lines are probably better than when it left the factory!russ92xmsed wrote:Perfection!
- raynoon
- Orga / RP numbers: 6043
New front discs and pads for KVG today. Mister Auto special at £28.
- raynoon
Another first for me... Glow plugs changed today, wasn't as difficult as I thought. Schoolboy error tho... The feed for the glow plugs wasn't connected resulting in it not starting and me scratching my head....
Well done Ray and you are certainly keeping busy. There is always something to do if you have several cars like us! Regards, Matthew T.
I remember when I did my first glowplug change. I was dreading it due to other people's experiences and knowing that glowplug four is very tight against the pump. But it was very straight forward in the end and I actually really enjoyed it!
