Sunroof/Headlining part
Eddie nuff
Post by Eddie nuff »
Anyone breaking an XM with a sunroof. I need the black plastic that sits around the sunroof opening. This is the part that is fixed to the headlining and sits between the headlining and the fibreglass mould.
I could do with some Xantia bits as well;
Full set of original floor mats
Headlamp protectors for both S1 and S2
Engine bulkhead sound deadening piece in as new condition
southerner
Re: Sunroof/Headlining part
Post by southerner »
You engine bulk head which part, as I have strip a mk 1.6 dt estate all that is standing is the shell in the back garden which i will be cutting for the scrappers (all other parts that are left are stored in the garage,
Eddie nuff
The car you're breaking is a 2.1 XM, the bulkhead sound deadening I need is for a 1.9 Xantia.
southerner
yes sorry 2.1 td xm. the tarry stuff that is stuck onto the blukhead some of it is removable not sure where i put that i know i still got it. also kept the bonnet with sound damper
