Basically in a nutshell, we are changing our lifestyle a bit, so some of the projects MUST go, now that means they get sold here or they get scrapped if no takers. I am sorry for being so blunt, but this is the situation im in.
So...
L reg BX TZD estate many miles and a few little jobs needs doing (octopus ideally and a regulator rebuild, maybe a clutch. The car has lots of good aspects, little rust, lots of new pipework etc.
K reg BX 16TXI needs octopus also and probably valve stem seals and a going over.
XM no longer for sale a because I'm an idiot and in deep deep smelly stuff with the other half !
Im asking only around scrap money, depening on each cars good/bad bits.
Any takers please get in touch.
Citroens must go, Edited!
stinkwheel
90 XM 2.0i 8v
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
Re: Citroens must go, rare ish early XM included
Hi. Where are you?
mds141
- Orga / RP numbers: 8542
I think Matt is in the Northampton area.
Mark Smith.
1997 Honda Firestorm.
stinkwheel
Absolutely correct, Northamptonshire, near Kettering.
90 XM 2.0i 8v
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
Ciaran
- Site Admin
- Orga / RP numbers: 1234
5678
91011 - Location: Ireland
Gutted, I have friends in Wellingborough I visit every so often, I'd have snapped up that series 1 XM if I was due over anytime soon!
Ciarán
Ciarán
That is the white XM as seen at the National and 25th I believe and was there an earlier thread with pictures and other info! It is a shame you have to pass on the car Matt but hopefully a good home will be found! With regards, Matthew T.G reg XM series 1, 2nd earliest car known left in UK rhd form, basically works apart from intermittent starting issue (probably fuel pump related)
stinkwheel
How soon will you be over Ciaran? There is a little sorting out time
90 XM 2.0i 8v
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
stinkwheel
MTXM wrote:That is the white XM as seen at the National and 25th I believe and was there an earlier thread with pictures and other info! It is a shame you have to pass on the car Matt but hopefully a good home will be found! With regards, Matthew T.G reg XM series 1, 2nd earliest car known left in UK rhd form, basically works apart from intermittent starting issue (probably fuel pump related)
Thanks Matthew,
We are staying with the XM for charlotte, she is getting a S2 2.1 TD at the weekend. This one is just not fair to be used all the time and we have too many cars anyway
90 XM 2.0i 8v
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
Ciaran
- Site Admin
5678
Probably not for 6 months or so and it's not definite unfortunately...
Cheers though
Ciarán
Cheers though
Ciarán
stinkwheel
ah. fair enough
90 XM 2.0i 8v
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
94 XM 2.1 TD SX
97 XM 2.0 16v Auto
