Early Mark 1 2.0 Prestige Manifold wanted
very tall brad
Post by very tall brad »
For a 1992 8v non turbo 2.0 XM. Mine has a crack. I think it's repairable but I could do with a spare, just in case, please.
Am I thinking these will be the same as on a Xantia?
Citroen XM Prestige 2.0 automatic RP5665 (1992 K) owned since 1996.
Re: Early Mark 1 2.0 Prestige Manifold wanted
Brad these are specific to the xm engine with Bosch and I think magnetti management pug used a different setup as did the xantia.
Ive just checked Service Citroen, and YES the exhaust manifold is the same as ALL 8v ONLY Xantia Mk.1 Engines (UP TO 1997)
16 v manifolds are different!
I Should just give up with this, useless :lol:
Yes the Exhaust manifold is common across all 8v lumps using the same block with between 1.6 and 2.0 displacement, they are well known for cracking. 8v xantias are a bit thin on the ground now, you do get the odd 205gti one come up for sale if they have had the stainless 421 manifold upgrade but because cracking is common finding one may take a little while, unless your near that white breaker?
Again as Paul says 16v heads dont fit as they had 8 exhaust ports with tubular headers rather than the cast afair the 8v got.
I noticed the 8v manifolds are available on xantias HOWEVER the 16v manifolds are NFP....
That is surprising.
very tall brad
Thanks, I'll see what I can find in some French breaker yards where there are hundreds of Xantias and XMs.
If that's the case you do well to buy a good few and stock them ready for the next person!!
Eddie nuff
Post by Eddie nuff »
or at least pass on the info.
