looking fo a brake sensor unit
samkelencube
XM newbie
Post by samkelencube »
im samkele ncube resides in zimbabwe ..im looking fo a brake sensor unit fo a citroen xantia MAKE sedan manufacturing yr 2000
Re: looking fo a brake sensor unit
Post by xantia_v6 »
Welcome to the forum.
This forum usually specialises in the Citroen XM, but there might be a Xantia expert lurking...
I would suggest that you try http://www.frenchcarforum.co.uk" onclick="window.open(this.href);return false; where the Xantia experts hang out.
You also need to be clearer about what you want. Is it an ABS sensor you need? Front or Rear?
