Post
by citroenxm » Thu Sep 15, 2016 9:11 am
And911 wrote:Car looking fabulous Matthew, sorry to hear that the gearbox turned into more of a saga than anticipated. I keep looking out for a similar example but it's not easy to find one to this spec, impossible in the UK to be honest. If only I had been a little more persuasive when it was in pieces in your garage!
im increadbly guilty of letting my V6 SEi sit for far too long with the hope of a resto.. which simply wont happen firstly because she sat out in a dampish area and not under cover and now because time is increadably limited... the sitting out in grass damp resulted in cills gone and inner cill walls that meet the floor etc also rotting away.. ill hate myself for it but its done now nothing I can do about it. She Is a later 1993 K reg. So improved spec with cruise control added at factory and all colour coded trim.
my attention needs to focus on my 24V manual S1 with what time ill have.
Post
by MTXM » Thu Sep 15, 2016 11:17 am
Thank goodness it was only a seal, but as I said to you at the rally Matthew, if they did replace ithe seal when it was rebuilt, it didn't last long, or it wasn't replaced at all, which is a bit of an oversight.
The governor seals were replaced before the rebuild in 2010 and at around 10K miles ago Russ when earlier problems arose. Nevertheless I agree the lifespan seems fairly short. It appears the failure is not uncommon but luckily quite an easy fix and it might be that wear inside the governor chamber is a factor. Regards, Matthew T.
Post
by MTXM » Mon Sep 26, 2016 12:59 pm
I have now put over 1,000 miles on the car after replacing the governor seal and the changes both ways now seem to be getting smoother all the time! It might be tempting fate, but hopefully after many trials and tribulations I now have this car sorted for the foreseable future. Regards, Matthew T.
Post
by russ92xmsed » Mon Sep 26, 2016 6:58 pm
That's good news. Keeps those fingers firmly crossed! Maybe it just needed a good bedding in after the rebuild.
It does look good though.
Post
by Dieselman » Mon Sep 26, 2016 7:09 pm
If the governor seals have been leaking the shift valves wont have been receiving full hydraulic pressure. It's possible they have been sticking as a result and they are freeing off as the valves are moving better.
Post
by MTXM » Mon Sep 26, 2016 8:04 pm
Thanks chaps and I think tbh I think any XM looks good in platinum Russ! That is an interesting suggestion about possible sticking valves effecting the gear shifts Will and they certainly must be loosened up by now! With regards, Matthew T.
MTXM on Tue Sep 27, 2016 8:51 am, edited 1 time in total.
raynoon
- Orga / RP numbers: 6043
Post
by raynoon » Tue Sep 27, 2016 7:22 am
Looking good Matthew!
Post
by MTXM » Tue Sep 27, 2016 8:51 am
Cheers Ray that is kind. Regards, Matthew T.
Post
by MTXM » Thu Sep 29, 2016 8:52 am
Just a quick update on a couple of recent cosmetic improvements that were to swap the front seat bases and replace the bonnet lining. I have done the seat change on all of my cars now I think and it makes the world of difference and almost like a new seat. The base takes most of the wear and especially along the outer edge, which obviously then becomes an inner. As Rob pointed out at the Chevrons my bonnet lining was in quite a state with facing material missing and generally grubby and tired. I had a very tidy liner on a spare bonnet and I also took the opportunity to clean and modify the light that has been very successful. Regards, Matthew T.
Post
by russ92xmsed » Thu Sep 29, 2016 12:42 pm
Do you mean you swap the passenger seat base with the drivers base? Good idea if that's the case.
I also swapped my bonnet lining recently. The original had some foil, possibly as a heat reflector, glued on to it. That had peeled off and was half hanging down.
It's a shame as the rest of the lining is in brilliant shape, but it looked dreadful with brown dried glue all over it.
But Mr Thomas... What about that rear door? Bit rusty along the bottom seal.... Sorry I shouldn't be pointing that out.
