Guys, my pump has started leaking from somewhere unknown as of yet, so im looking for some help on resolving the problem
Whats out there in the way of a solution? replacement pump? andif not can the seals be changed in situ?
Wanted: Bosch 2.1 injection pump
Re: Wanted: Bosch 2.1 injection pump
I admittedly took the expensive option and had my pump totally resealed with our local Diesel specialist. If you can get the pump off Vince, you might have someone able to reseal it for £250...possibly cheaper. If your brave there is a good how to write up on it somewhere. The actual Bosch seal kits are only about £15. Mine however was totally overhauled, new stop solenoid, completely cleaned up and it was all reset and re calibrated. The car was transformed after this and ran beautifully. So although it was a bit of a hit on the wallet, I think for my one it was worth it. Problem is I really want it on my mandarin one now!
Fair enough Russ for wanting to keep it for your mandarin one
No doubt my pump seals have deteriorated whilst the car has been stood not running for a year and half
The car has always run fantastically since buying it from Paul and its had such extensive engine work done in its recent history im sure the pump is otherwise tip top. A seal kit im sure will do the trick to have it purring again.
In the meantime, i may have found a solution to help me stay mobile whilst the old pump gets re-sealed
mds141
- Orga / RP numbers: 8542
Et voila...http://www.ebay.co.uk/itm/231306005703
Mark Smith.
1997 Honda Firestorm.
Yikes!
nice price. A full pump reseal with labour and vat is cheaper than that.
I'd never buy that new one but get the old one resealed.
Rommel
Vince haven't you seen my ad?
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
ES9 V6
Previous:
2.5TD VSX Estate
I have Rohan but is it the same pump? Someone said it was from an auto?Rommel wrote:Vince haven't you seen my ad?
If they are the same, I'll still get the one that Paul has as he is going to swap it over for me aswell, but i might be interested in yours anyway?
