Oh blimey! Thankyou Andrew, got those sizes mixed up ... What about the ones on the front of the subframe on the steering circuit???
Hydraulic Connector needed for mot
Re: Hydraulic Connector needed for mot
- Orga / RP numbers: 5678
This 4.5mm pipe feed to the back goes from the ABS in front of the gearbox all the way to the rear subframe and coneects to a 3 way connector which feeds the rear brakes through 3.5mm pipes. Then 4.5mm pipe is in tow sections with a two way connector under the passenger footwell.
1992 build 2.0i Prestige Auto
This is the part you need. A Citroen dealer or plaiedes could supply if no-one has one, or even a hydraulics suplier might be able to supply a straight coupling for 4.5mm pipe.
