Post
by Dieselman » Wed Feb 19, 2014 8:18 pm
dollywobbler wrote:Thought it was biting well! Did have one horrible moment when the editor slammed it for a shot, and I then couldn't get the height control to move again... Had great fun explaining the handbrake complexities as well.
That is exactly the same parking brake mechanism as used by Mercedes, except their release is spring loaded to always be engaged.
Did you remember to lift the height control knob when trying to move it. I'll check it, but it's never been a problem on that car.
Post
by russ92xmsed » Wed Feb 19, 2014 8:56 pm
citroenxm wrote:If its a group test I HOPE DAMM WELL Theres a Renault 25 in the group! Else I will be disapointed!!
So do I!
about time these cars get some mag coverage. We'll have to wait and see.
dollywobbler
Post
by dollywobbler » Wed Feb 19, 2014 9:19 pm
Dieselman wrote:dollywobbler wrote:Thought it was biting well! Did have one horrible moment when the editor slammed it for a shot, and I then couldn't get the height control to move again... Had great fun explaining the handbrake complexities as well.
Exactly. The Merc is a one-foot operation, rather than a hand and a foot.
Did try lifting the lever, but it didn't seem much like lifting (don't worry - this sort of detail would never be included in a feature anyway, especially if it's operator error!). At least it's a mechanical lever rather than the silly electric mechanism on my Series 2 CX (which frequently went all funny).
1986 2CV6 Dolly, 1980 Dyane
Post
by Dieselman » Wed Feb 19, 2014 9:26 pm
I always push the release knob back in once the brake is off, so next time, just push the pedal down.
Post
by citroenxm » Wed Feb 19, 2014 9:28 pm
I NEVER do Will. It can encourage Ratchet WEAR!! You dont pull on a Standard hand brake without pressing the button in?? Do you??
Post
by Dieselman » Wed Feb 19, 2014 9:38 pm
I virtually never use the parking brake. The Mandarin car sits without any brake applied, the Cobalt one is normally in gear, no brakes.
It's a pretty robust mechanism. My first XM got the brake applied about 20+ times a day for 50,000 miles, no issues. I never use it for hill starts, just swap my foot over from brake to accelerator and pull off before it rolls back.
djg
- Orga / RP numbers: 7261
Post
by djg » Fri Feb 21, 2014 4:14 pm
I wonder if it's really wise considering that the parking brake is also an emergency one. Granted, not a very strong one...
Bye,
Gábor
1996 XM 2.5 Turbo D VSX (LHD, Bleu Mauritius)
1996 AX 14 D (LHD, Alaska White) in family
Post
by Dieselman » Fri Feb 21, 2014 8:02 pm
You would always have time to release it again if necessary.
Post
by citroenxm » Fri Feb 21, 2014 8:03 pm
DONT Agree Will...
In a panic, there IS NO Time to think, which you really would need to do...
Post
by Dieselman » Fri Feb 21, 2014 8:08 pm
Have you tried using the parking brake as an emergency brake?
It takes as long to stop the car as an Inter-City 125.
